Most likely problem is that the unloader is bypassing water. As unloader wears it will by pass at lower pressure. Try lowering the pressure at the regulator to lowest setting then raise pressure a little at a time untill unloader releases then lower to prevent unloading. Using a slighly larger tip will do the same thing. Using a larger tip size lowers pressure.
