Question about White Sewing Sewing Machines
I have a white model 365, made in 1967. Has worked great. But why will it not make a stitch. It will feed the fabric, but for some reason a stitch is not being made.
  • marsha841 Sep 13, 2010
    The bottom thread is being picked up by the needle. It is just not making a stitch.
  • 736 Answers
Sometimes this happens when a lot of lint has accumulated in the feed dog area. That's what was wrong with our machine the last time this happened to us.
Posted on Sep 14, 2010
    Brigadier General:
  • 3,917 Answers
Hi
It the bobbin thread is not picked up by the needle thread it wont stitch.
Check the bellow link:-
http://www.ehow.com/how_5306171_thread-bobbin-white-sewing-machine.html
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 13, 2010
The feed dogs on my sewing machine will not raise
if your question is that the fabric didn't feed when I tried a zig-zag stitch , well then this might be a normal thing to happen on your machine , some machines when set to MAX size zig-zag stitch retract the "feed dogs" as you call them so that the operator can hand move the fabric around under presser foot , this is task called "darn" and its usually for filling large holes in fabric (socks!!) and for adding embroidery too (special needle)
Oct 05, 2016 | Sewing Machines
I have the dreamweaver machine and it uses the button foot for darning. makes a great stitch vertical but how to you make it make the horizontal stitch
Usually the stitch width selector would do that.
Um, just curious. If you are darning, you would manually maneuver the fabric to go forward and back and side to side. You probably wouldn't want to use a wide stitch for darning. Also, for darning, you would probably want to use a darning foot or free motion foot. They are both shorter than the standard presser foot so there would be no pressure applied to the fabric, especially when you drop the feed dogs. Technically, the feed dogs wouldn't be feeding the fabric, you would by hand.
https://www.youtube.com/watch?v=GtLj0iJnvqM
Aug 28, 2016 | Sewing Machines
Refuses to sew on thick fabric why?
Here's a pdf of your manual Singer owns White's manuals now.
http://www.singerco.com/uploads/download/864_white-970,972,979-x-.pdf
Typically you need a longer stitch to sew thicker fabrics, have you tried that yet?
Dec 13, 2012 | White Sewing 979
Baby lock serger will not feed, fabric want come out from under presser foot.
what is the stitch length set to? should be 2.5 or thereabouts for normal serging.
Is the pressure foot pressure turned up too high perhaps?
The reasons I could think of for it not feeding through would be:
- the feed dogs under the pressure foot are out of position/not moving
- that the differential feed is turned up so its pushing the fabric back to the front of the machine
- stitch length is set very low so hardly moving the fabric at all
- or youv'e got a thread tangle happening around the foot/blade area.
Jun 14, 2012 | Sewing Machines
There are different kinds of single needle foot, What are these?
If you take a look at this website you'll see the different feet for some makes
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
I assume you mean what are the different feet used for?
General purpose foot will have room for the needle to swing through wide stitches, but enough foot to hold the fabric and move it through against the feed dogs. This is the one you use most.
A straight stitch foot will have a little hole so that the needle only goes through a small area and the fabric can't move to give a neat plain straight stitch.
Plastic wide toe foot is good when you need to see what you are sewing onto such as applique (sewing a piece of fabric onto another with a wide satin stitch).
Teflon coated foot is good for slippery fabrics, it grips well.
A roller foot is great for textiles like leather and vinyl which don't feed nicely.
Then there are lots of feet for turning the fabric to sew it such as a rolled hem (these come in different widths so you can turn 2mm, 4mm or 6mm for example).
Felled foot (like the side seam on your jeans) joining two fabrics in a felled seam
Then there are feet for quilting and darning where you need to move the fabric smoothly in different directions, these will be small foot area and open stitching space usually.
Walking foot is a special one, part of the foot moves because a part of it clips around the needle bar and the up and down movement then activates the foot so its little teeth help to move the fabric from the top to supplement the normal feed dogs below. Pfaff machines actually built this function into their machines some years ago to give even feed from top and bottom. Great for quilting thick fabric sandwich or sewing together fabrics that want to slip or not feed smoothly.
There is also similar info here http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ which may help you to see the different uses and feet available.
Most manufacturers will sell their machine with 4 or 5 of the most used feet but often have more to buy aftermarket. And many feet between companies look very alike so if you have a clip on foot from one brand it may work on another machine with a clip on foot.
I hope that this is what you were asking.
May 26, 2011 | Sewing Machines
Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
May 29, 2010 | Juki TL-98Q
How to use a blind hem stitch foot on the White overlock 2000
The blind hem stitch foot is actually just a guide to keep the folded edge of the fabric away from the cutters, and close enough to the needle, to catch a snippit of fabric to actually hem the item you are feeding thru the machine.
The trick is in the folding, and this vid clip is a good guide for the folding technique. Keep in mind that the 'lip' of fabric she is talking about will be overlocked, and your hem will have alot more 'give', providing a stretch that would be helpful for a stretch fabric.
http://www.ehow.com/video_4407404_machine-sew-blind-hem.html
Mar 16, 2010 | White Sewing Speedylock 1600 Mechanical...
Feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Jun 27, 2009 | Kenmore Sewing Machines
Have a Necchi 3205FA and trying to figure out how to set it up for serging. DVD wasn't much help.
There is a serger attachment available for that model. When you attach it to the machine you must start the fabric from the top of the foot. The foot won't cut the fabric if you feed it under the foot. You will want to use the Wide zigzag, overlock, or hemstitch stitches. Set stitch length knob on #4 for overlock stitch #1-0 for hemstitch or zigzag. Set the stitch width to the maximum. Make sure the hook arm is inserted over the needle screw so that when the needle goes us and down the attachment will work. Start on the edge of your fabric by making a small cut about 1-2 cm deep and about the same distance from the edge as the cutting blade. This will make it much easier to feed the fabric over and then under the foot. Remember to start the fabric on top of the foot and then feed it under the foot before it reaches where the needle would penetrate.
Nov 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Open Questions:
Sewing Machines Logo
243 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
