I have a kv36fv15 and have went into the service menu to make some minor adjustments however i seem to have messed everything up .what are the factoty default settings
  • 2 more comments
  • billkoppler Sep 13, 2010
    this only resets the user settings not the service settings - i need a list of what the factory settings are
    i need a list of what the factory settings in the service menu should be so i can go in and reset them all
    this only resets the user settings not the factory service settings i nee a list of what the factory parameters should be set to or a loction i can get this info
  • billkoppler Sep 15, 2010
    this does not reset the service adjustments only the user adjustments i need a complete list of what the factory settings on the service menu are! not the user menu Thank You
  • 10,594 Answers
Press 8 then ENTER on the Remote Commander to reset all service data to factory default settings.
Posted on Sep 13, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Sep 13, 2010
    First go to service mode then press 8 then enter on remote, we call it Initialize service data, all the service data will be reset to factory default settings.
    Also try 8 then 0
    Or 8 then Mute on remote
    Shahid Electronics Sep 15, 2010
    OK, you need to get service manual copy that has all service data list.
    Click THIS LINK and download all 15 files of related service manual then unzip it with Winrar software to get PDF manual file.
    Let me know if you have additional question.
    Thanks.
    i already have this service manual it does not list the service settings only how to enter the service mode and tells you to write down the deault settings before adjusting which i failed to do. Where can I find what theese values should be
    what is file size of service manual that you have?
    I can see service data list starts from page-24 page-29
  • 5,807 Answers
Enter the service Mode using the remote.
Then press “8” then “Enter.”
This will reset the CPU, turning the set off then back on
automatically.
or you may have the option:
Replace the CPU (IC001)
Use following steps to reset channel, but I lost the sound 1. Unplug TV 2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen) 3....
img{-moz-force-broken-image-icon:1;} Same no sound issue happened to me; except I stopped at adjusting vertical size (unfortunately it seems horizontal cannot be set thru service mode; which was my original intent). Complete lost of sound signal processing; oddly enough speaker volume leveling did worked. (Eg, audio-in woks; so a big WTF?!) I suspect something to do with not recovering properly the data bus from muxing the volume input keys; ie, some kind of weird service/back-to-normal switch bug. I've waited for a couple of days for the damn thing to unlock itself out it (like some stubborn transistors seem to do); but to no avail. (BTW, only dif between TVs is that mine's a slightly smaller and cheaper model, a 19U-M100S; a minor branch out of the main line.) I'm afraid something did "burned out" and that the only real fix is to actually change the "defective" part. Had I known silly sh1t like that could happen, I obv would've not messed with it to begin with. It's just ridiculous, and lame. Besides being obsolete. In any case; I also think it's nowadays better to get a (full) digital one (wisely cost effective).
Oct 16, 2010 | Sharp 25N-M100 25" TV
Tried to auto adjust the guns, will not come within range
Hi Tod,
If colors do not align correctly, most likely you have a convergence failure. This requires replacement of the 2 STK ICs and possibly some low ohm resistors.
Some Toshiba have a Horizontal oscillator/Drive IC failure that results in a small or shrunk picture (2-3" border on all sides). The 3 colors do not align properly because of the reduced Hor drive signal. The convergence adjust controls will work but not allow good adjustment. Convergence is ok, Hor Drive signal is incorrect.
Many do-it-yourselfers mistake the Hor Drive problem in Toshiba RPTV with convergence failure. Too much adjustment of the convergence controls may cause the saved data to be really messed up and require more difficult alignment in the service mode.
If minor or simple adjustments in the customer convergence adjust menu do not fix your problem, there is a fault. Stop adjusting until fault is repaired
Convergence failure can be accurately identified with the Convergence Gallery on our website. Service in Toronto, Ottawa, Calgary, Edmonton and other Canada cities.
easyab
Apr 21, 2010 | Toshiba 42H81 42" Rear Projection...
Messed up Image
You need to replace both of the convergence ICs. They are both STK392-570 you can get replacement ICs at the following link and they provide free instalation instructions with pictures on how to replace the ICs. Here is the link.
http://servicemanuals.vstore.ca/
Jul 08, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Resetting lamp hours
You will need to enter the service menu to do this. However if you were to push the wrong button on the remote you could really mess up the tv. So I suggest you call Sony and see if you can get an ASC to do it for you for a minor charge. There are literally hundreds of electrical adjustments in this service menu. I would adcise an asc do this for you.
Jan 23, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
RCA Home Theatre System 51 or 52"? Chassis # PTK169PAAS
If it is a "minor" convergence problem you can adjust it by going to the menu and scrolling to convergence and follow prompts A cross will appear when you have reached the correct place and you do the minor adjustments as it says. If picture is bowed you have major convergence problems.
Jan 05, 2008 | RCA 32V420T 32" TV
Messed up Image
bad connection on convergence amps or need to replace them
Oct 11, 2007 | Mitsubishi VS-50805 50" Rear Projection...
Samsung HC-P4752W No Color
Do not automatically think you need to go into the service menu. I bet you 100 to 1 that you pulled out a plug or a connector somewhere OR one is not seated into the plug all the way. If the set worked with color before you messed with it, there is not a problem in the service menu. The service menu is not the fix all thing. it is there to make fine alignments and adjustments, and as a matter of fact, messing with a service menu even with the service manual is very dangerous. I have seen peeps ruin TV sets by messing around with the service menu alignments. STAY out of these alignments. they are not going to fix a problem that all of a suddenly comes up. Repair the problem in the circuit first. Good Luck
Sep 18, 2007 | Samsung HC-P4752W 47" Rear Projection...
Convergence problem w/ red horizontal only-WS-65807
Do not try to adjust anything yet!! Adjustments do not get out of alighnment all of a suddenly. The convergence adjustments are there to do minor aging alighnments. I would first check for bad solder connections on the convergence IC's first.
Sep 08, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Help please stuck in service menu
You should have purchaced the service manual before you went into the sevice mode, as the service mode is a dangerous place to be if you do not know anything about it. You can get the service manual from www.servicemanuals.net for about 20 bucks or so. A lot less expensive then a serviuce call I would think.
Aug 02, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 43H70 convergence
You will have to contact toshiba at 1-800-457-7777 and get a service manual to adjust the on board menu and adjustment.. I do not or ever ever recomend that an unexperienced person mess with the sets alighnments unless they have the service manual and understand all of the teminology as I've seen several sets that cost the customer 4 times what it would have if they didnt mess with the service menu and knock all the alighnments as this is not the time to adjust someting just to see what happens.
Apr 08, 2006 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
