Hello there,
Are you sure you battery pack is fully charged? If yes then there is a hardware problem on your camera that's why when the system detected that, it automatically shuts itself off. Usually this is caused by a lens error. The camera cannot retract out the lens because there may be a grit of sand or dust build up in between the lens barrel and the camera. Here is what you try to do:
Hold the camera with your right hand with the lens facing the ground. Then hit the camera's base to your left palm as you turn on the camera. This aims to take off that grit and the lens to retract out. You may need to do this several times.
Please let me know how this goes.
Base from the description of your problem this can be an issue with the lens of the camera, first thing that we need to do is to make sure battery is fully charge.
Then power on the camera , Press the Playback button on the back of the camera , the lens should retract and camera should be fine after that but if still same problem try this following steps.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum .
Sorry but there's no reset button on this camera and doing those procedure that I provided you and still camera not working, the issue here now is the lens mechanism inside the camera and the only way to correct that is to have the camera dismantle and also clean from inside , and to do that the best thing is to have it check to a service center to avoid further damage.
I tried all the recommended solutions, but it still beep three time and
power turn off. My lenss shutter opend and now stay open and
does not close or turn to close it. Just beeps three time and immediately
power turn off.
Are there any reset pin or hole to reset camera?
Thank you.
Raju
Do have doc that show step by step instruction on how to open it?
