I have a asus M4A785TD-V EVO MB 4GB OF DDR3 RAM. Mother board + video card SAPPHIRE HD5850 3D , BUT I GET NO SOUND FROM THE SYSTEM IT . It GIVES An error marked ON THE DEVICE MANAGER UNDER THE SOUND TAB FOR AUDIO DEVICE ON HIGH DEFINITION AUDIO BUS & every time i restart the system gives a popup that a new device is installed and their are no drivers in the asus drivers cd for these. I'm posting with no OS stated, to make this harder, and not asking at ASUS dot com.
Can be a hardware problem so get a usb sound card, they're cheap
well it has 3 sound ports.
non stated.
sure add 4th sound device, more is better.
not;
its not a hardware problem
the driver is missing for his sound, he clearly shows that in device manager.
that is wrong is he fails to stated OS he runs
not if internet connected
nor of he looked and sees the drivers at asus.com and failed to load them.
BTW W10 don't run on this PC. many dead chips. if you try,
amd chips at the worst this old.
as are that VIA sound chip, hopeless.
The the OEM ASUS, does not support W10?
I think W7 is max here.
but the AMD bridge chips
are here
SB7 series it is.
amd does have drivers for newer OS seen below. this may make it more stable.
https://www.amd.com/en/support/chipsets/...
Try this driver from Asus website:
M4A785TD EVO Driver Tools Motherboards ASUS Global
http://dlcdnet.asus.com/pub/ASUS/misc/audio/v7900d_20100329.zip
It's intended for Win 7 but could work in Win 8 and 10 as well.
Note that asus has no support for this M/B above Win 8.1
// Good Luck
Hey Nishit you can also try this to rule out audio is enabled in SERVICES > PRESS Windows an R key on your keyboard in the runbox that appears type services.msc and scroll to windows audio it may be just audio on version your using and make sure it is enabled on automatic and is also running if not press START AND SET TO AUTOMATIC...do not mess with any other settings in here as you can crash your O.S. just what i stated if it is running >my computer advanced here is a set of 4 tabs in one is a setting to also install device drivers an icons as you get updates from windows update make sure this is also pressed to always install the best drivers from windows update if all else fails uninstall the entire device via device mananger it may have a mis or corrupt configuration after uninstalling reboot and both the device and driver will reinstall the device will prompt with a found new hardware allow all and second driver will install itself if none work repost ...hope this helps... still no luck googl iobit driver updater its also on cnet it scans your device and finds oudated or not installed drivers and actually finds them with the free version you have to install one by one manually but in a pinch its worth a shot just as a rule of thumb you should only download driver updates from the OEM THESE ARE ALWAYS FREE JUST FIND PC SERVICE TAG AND SEARCH OEM SITE AND ALL YOUR DRIVERS WILL APPEAR DO REPOST IF CANT GET A DRIVER THANKS
Sounds like you need to either reinstall the driver or find an updated audio/sound card. Install this driver despite what windows 10 says if you are using window 10 that is if windows 7 or 8 this should work. Your system is 64 bit This link my help https://www.asus.com/za/support/Download/1/24/38/8/29/
SOURCE: SOUND PROBLEM
* i think you haven't register o.s
* if o.s is register it will not support some drivers to be installed
SOURCE: ati sapphire support
then this card is not supported by the motherboard and wont work or be recognised. For a list of supported vga cards try www.pc chips.com.tw/pccwebsite/support
SOURCE: driver for high definition audio device
Hi dear, you can find and download your required driver free from the following links; just click and get driver for life time.
http://www.nodevice.com/driver/P5AD2-E_Premium/get34049.html
http://www.driverfiles.net/Bios/ASUS/P5AD2-E/download/page,sh,30034,172,6,.html
http://drivers.softpedia.com/get/BIOS/Asus/Asus-P5AD2-E-Deluxe.shtml
http://www.driverstock.com/ASUS-P5AD2-E-driver-download/6-9-10126/index.html
http://www.findmysoft.com/drivers/download-Asus-P5AD2-E-Premium-Bios-1-03-firmware-driver.html
Good Luck
SOURCE: ASUS P5B-E: No Sound after reinstalling XP SP3
THERE IS A SET OF NUMBERS ON THE MOTHERBOARD WHICH ALSO INCLUDES ASUS P5B-E IF YOU GO ON GOOGLE AND ENTER THE MOTHERBOARD NUMBERS YOU SHOULD BE ABLE TO GET THE CORRECT COMPANY & DRIVERS FOR THAT BOARD... GOOD LUCK
SOURCE: Hello, My son just got the M4A785TD-M EVO with
sounds like the ram is not pushed in all the way, try double checking all the connections
wysiwyg, what you see is what you get.
the drives are here.
what you see is all there is,
https://www.asus.com/us/Motherboards/M4A...
why not start at the official asus
support page for you mobo.
as you can see w10 is NO GO;.
