Question about FrancisFrancis! X5 Espresso Machine
Water is only coming out of the steam valve not the coffee maker part
No matter which button I push, water is only coming out of the steam valve. I can't get the machine to make coffee. I only got it two days ago. I made one cup of espresso and now water won't even come out of the coffee maker part of it.
    Problem Solver:
  • 10 Answers
I apologize if I offend you in saying this, but perhaps check the steam knob and make sure it is off, turned all the way away from you. If the knob is even a little bit engaged the water will bypass the brew group significantly.
Otherwise, your shower screen may be severely clogged, though I doubt this is the case if you have only made one cup of espresso. Give it a look though, and scrub it off with hot water and a grouphead brush--or a dedicated vegetable scrubber brush (my preference :)
Posted on Apr 01, 2009
Steamer not working
Try this push in on the steam knob after it is turned on if that works the steam valve assembly needs to be replaced.
Sep 07, 2014 | Saeco ODEA Coffee Makers & Espresso...
Coffee grinded but no coffee coming through
Got water in unit? is it heating water? is there a blocked pipe so no water come through? for last 2 remove coffee handle push button to pour coffee and see if water comes out and if it is steaming hot.watch ,don't touch hot water .
Sep 06, 2014 | DeLonghi Esclusivo Gran Dama EASM6600...
When I push the button to make espresso the water comes out through the hot water/steamer? No coffee is dispensed but seems like all is working inside?
The water pressure is high possible because the grind is really fine, however water is not supposed to go through the valve unless it is open, you might have to replace the steam valve assembly.
Apr 25, 2011 | Saeco Incanto Classic Espresso Machine
We have this machine that we purchased in Italy in 1995 and it heats (left button) and steams but I can't get the water to pump (right button) through the coffee to go into the cups. Makes a loud clicking...
Obviously you have problem with non return valves at the pump, they are built inn the pump.
  • Remove the filter holder, open the steam valve and command brewing coffee. If water comes from steam valve close it> continue brewing and wait the water from coffee group. After this procedure test it with coffee.
  • If testing with coffee is successful you may work with that pump but always be careful to not leave empty water container.
  • If testing isn't successful you need to change the vibration pump.
Feb 24, 2011 | Elektra (SX) Espresso Machine & Coffee...
Initially when the unit said need to prime, no water would flow out of the steam unit. After pulling the pump out and cleaning it, not sure what was blocking water the steam unit now has water pressure,...
I fixed the same issue by pushing in the water knob "in" towards the machine. Machine than primes normally as the water flow is restored and it resets itself.
Dec 13, 2010 | Starbucks Saeco Italia Digital Barista...
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
Water does not flow through the coffee group but only exits viasteam pipe. Decalcifying and cleaning or resetting factory settings do not solve the problem. what to do?. The problem occurs after I have...
Hi
When you are finished with steaming, try pushing the steam button again and then opening the steam valve to purge the steam. Do this until the water flows freely. You should hear the pump change tone. If you have a pre grind button, try that without putting any coffee in the pre ground chute, then push a medium coffee. Water should flow through the brew unit freely. If not, you are getting a blockage in the brew unit. If it does, your grind on the machine might be too fine. Change to a coarser grind and try again. It usually takes 3 cycles before the grind is in effect.
Aug 22, 2009 | Gaggia Titanium Espresso Machine
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
FrancisFrancis! X5 Espresso Machine Logo
352 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
