Question about Karcher Garden
Karcher model K1800 IB: No outlet pressure through wand. I have cleaned the inlet filter, has plenty of water and cleared the wand line befo9re starting.
gwshaw71
  • 83 Answers
SOURCE: Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
Posted on Feb 24, 2008
SOURCE: karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Posted on Jul 16, 2008
SOURCE: broken water inlet on Karcher
Had the same problem.Those hose inlet are very delicate.
I went to Home Depot,to the Garden Section in the hoses stand,and found a flexible connector for about $ 6.00 and I used it as a replacement for the broken hose inlet.
Good Luck!
Posted on Aug 17, 2008
  • 92 Answers
SOURCE: Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
Posted on Nov 04, 2008
  • 113 Answers
SOURCE: error code e4 on kenwood kdw12st3a dishwasher too much inlet wate
HI there,
I have had the same problem as most of you. I seem to have fixed it by
1. Bail out all the water from the inside
2. Remove the filter and 2 x mesh pieces.
3. Continue to bail out the water from the filter well.
4. You will probably find pieces of food or fat/debris in the bottom of the well. Remove these.
5. Tilt back the dishwasher at 45 degrees for 30 mins or so to drain and dry the flood sensor.
6. Boil a kettle and pour it down the well. Immediately put the dish washer on a eco wash (no tablets or anything) with half load (ie half water) and this will ease the water pump.
7. Let the dishwasher run its cycle.
8. Clean the filter again and the filter well.
It sounds quite long winded but with a £250 item you need to take care of it. Make sure you rinse most plates before loading in the future.
Hope this helps!!!
Good Luck!!!
neo
Posted on Mar 01, 2009
Where is the inlet regulator on my karcher 3300 high pressure washer
no inlet pressure regulator as they work of mains pressure
the only pressure regulator ther eis works off the wand trigger
when the trigger is pulled the pressure in the line drops off and the regulator switches on the motor to produce high pressure
when the trigger is let off the regulator reads the pressure and shuts off the pump;or allows the pressure to by pass back to the inlet side of the pump
Oct 30, 2016 | Karcher Garden
My Karcher KB 9030 has lost pressure and is hunting when no demand water supply is plenty
In most cases the water lines can have leaks that bring bring in air and so the pressure will be less. Power off the washer and let the water flow without any air bubbles. If you seen bubbles then recheck the joints.Check the same with the outlet.
If not there is fault on the main pressure pump.
May 02, 2011 | Karcher Garden
Folks, I have a Karcher 5.55 home water blaster that pulses at the highest pressure on the vario power spray wand. It works fine on the lower pressure settings and with the rotary spray wand. I live in a...
There should be a pressure regulator somewhere in the pump, check your owners manual or go on mfg. Site and see if you can find your model.
Aug 05, 2017 | Karcher Garden
My Kärcher K2.080 pressure cleaner (1450psi /
According to my search, Karcher has a 2 year warranty on this product. If you can get the serial number and model number off of it. They should be able to identify when it was made and then can honor that warranty. Otherwise the pump seals appear to be damaged by your description of the problem. Hope I've helped.
Best, Mark
Dec 28, 2010 | Karcher Electric Cold Water Pressure...
I have a pressure washer that runs but no pressure, I was using it at the time and all of a sudden no more pressure.
when running your pressure washer, if your running it at home make sure other appliances are not running also like a dishwasher or washing machine. when their pulling water it decreases the volume of water going to your pressure washer. if this is not the case. check the inlet from the water hose to the pressure washer, make sure the filter is clean. also the tips on the wand, make sure there is no hardwater build up. good luck!
Nov 22, 2010 | Karcher 2500 PSI Pressure Washer
Motor running, water supply adequate but when
clean whole water supply and outlet from all debris, clean inlet filter as well. connect water and pressurise washer, pull trigger and wait about 3sec for pump to activate, if pump do not activate adn you have pressure from nozzle as it will be from main, this determines pressure sensor (it is extremelly rare for pump itself) is damaged.
check if you have still warranty,this will qualify as warranty repair, if warranty is expired, pressure sensor need to be replaced.
if you find my advice useful, please do not hesitate to leave your remarks and vote for me, thanx!
Jul 31, 2010 | Karcher 1750 Psi Elec Pressure Washer
I have a John Deere AC2600Gh power washer and I can't get the soap to work everything else works great it just won't **** the soap up when I am pressure washing I know that it must be something simple to...
Soap will only siphon into hose if there isnt any pressure in the hose attached to the wand.Remove tip from wand and see if it draws soap into hose,back pressure in wand hose will cause the spring and ball to seat/close off the inlet line for the soap otherwise water would blow out of soap line.
May 17, 2010 | Karcher 2500 PSI Pressure Washer
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Karcher 294 no pressure motor hums
http://www.fixya.com/support/t2162702-karcher_electric_press_wash_hums_when
Mar 08, 2010 | Karcher Garden
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Garden Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
