Question about Acer NSK8458AN Keyboard
!> CAPS LOCk REMAIn LOCkEd @ nUMERICAL kEY nOT WORkInG
    New Friend:
NOT FUNNY OR HELPFUL
Posted on May 06, 2013
2 Suggested Answers
ralphspc
  • 74 Answers
SOURCE: How do I turn off the #$%^&# Caps Lock key?
remove the key...lol problem solved
Posted on Jan 29, 2012
I have an hp G42 notebook when i hit the power button i hear it turn on but nothing happens only the caps lock key light begins to blink
hp blink error code:
caps lock blink once: cpu error
caps lock blink twice: bios problem
etc,,,,
please, what is the numer of the blink ?
Feb 14, 2014 | Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
Caps lock light does not show
You can use the accessibility features of Windows to audibly notify you when you've pressed the Caps Lock key. Follow these steps:
Click on Start >> Click Control Panel.
Click Ease Of Access >> Select "Change how your keyboard works" from Ease of Access Center.
Check the Box for Turn on Toggle Keys.
Click Apply. Click OK.
The ToggleKeys feature, when turned on, will beep whenever the Caps Lock, Num Lock, or Scroll Lock keys are pressed.
hope this helps
Jul 29, 2012 | HP Compaq 6735s Notebook
I have an aspire 5532 num lock will not activate. I have tried FN and num lock together. The orientation operation works but the numerals will not show. The num lock is labeled white with no FN blue...
If the word NumLk (or NumLock) is written is white, then you will only need to press Num Lock key once to activate Num Lock
Usually software settings do not affect Num Lock or Caps Lock keys and should always work, unless there is a problem with that specific key.
Sep 19, 2011 | Acer Aspire AS5520-5537 Notebook
What is the third lock light, I have a Cap Lock, a Numerical Lock. What is the third one?
I beleive it is the scroll light:
Fn+F1 Suspend switch
Fn+F2 WLAN switch
Fn+F3 Keyboard light down
Fn+F4 Keyboard light up
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Ins Numeric Key Pad on/off
Fn+Num Lk: Scroll Lock on/off
Fn+Del Scroll Lock on/off
Fn+Space Power 4Gear
Fn+C Splendid
Fn+V: Life Frame
Jun 20, 2011 | ASUS 90-A4C1K1000 Keyboard
What do; the four little lights below my keyboard mean? One is the battery, one is the internet, but the other two? Especially the third from the lert with the icon that looks like a stack of pancakes?
The icon that looks like a stack of pancakes is the one for the hard disk drive and the indicator with the icon flickers or lights whenever there is hard disk activity. The reading / writing of large files will cause the hard disk drive activity indicator to light almost steadily until the file reads / writes have completed. There are two icons that look like little padlocks. One has the character 1 and the other has letter A. The padlock icon with the 1 in the middle is the indicator for NumLk or Numeric Keypad lock. Pressing the Fn key and the key with NumLk on it turns the Numeric Keypad on and off. When it is on, pressing the keys for UIOJKL will enter 456123 facilitating entry of numbers with the keys arranged as a keypad along with the top row of keys 789. Finally, the padlock icon with the A in the middle is the Caps Lock indicator which lights when the Caps Lock key is pressed allowing subsequent presses of letter keys to be capitals without having to press the shift key. Pressing Caps Lock a second time turns off the Caps Lock. Similarly, a second press of Fn and NumLk turns off the NumLk.
Mar 30, 2011 | Acer Aspire One PC Notebook
What's the best way to unlock a Caps Lock key that won't unlock by simply pusing the Caps Lock key to unlock it?
goto start > run > type "osk" and click ok...
On-screen keyboard will be displayed...
select keyboard in the menu bar... select 102 keys...
Use the Lock key in the on-screen keyboard... it will turn OFF/ON the CAPS lock
Jan 15, 2011 | Microsoft Computers & Internet
How to tell if/or when the cap lock and num lock are engaged, I was spoiled when the green lights told you the status. thanks
simply when caps lock key is engaged all you type is always printed in capital letters.in num lock without you can not use numeric keys that are located on right side of your keypad.uyou can always use your numeric keys which are up to ur alphabeticl keys.
if it helped you.plz rate it
Feb 22, 2010 | Microsoft Wireless Desktop 3000 Keyboard
My fujitsu siemens amilo notebook screen black.
Check num lock key of laptop press num lock if numlock key is on and off when you press it then dispaly working fine only issue with screen resolution .
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
But if num lock is constant when you press numlock key then you need to refix RAM memory.Open back cover of laptop then refix RAM memory.
Then check if still same issue then pull cmos cell from motherboard then check again if still same then try with another RAM .
When you power up the computer press F1 or F2 or "del" key if you are able to see bios screen then you not need to open back cover of laptop only make sure SATA is disabled and your harddrive is detected in bios.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Fujitsu Siemens Computers & Internet
Motorola w260g Caps Lock
Solution: Type a letter and press the 0 key. Happened to me too.
Feb 13, 2009 | Motorola Cell Phones
Acer NSK8458AN Keyboard Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
