Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Dualit espresso machine
By jelliebean on May 15, 2008
We have a Dualit espresso machine which had a blocked steamer nozzle. I descaled it but ever since, the machine has been leaking where the reservoir fits into the casing and the mechanism which caused the water to feed through the machine when switched on now opens the 'valve' thus making the water drip out of the machine on to the work surface whether switched on or off. This was fine before I descaled it. The steamer is working perfectly though!
J
Same Problem
Nov 30, 2008
-   I have the same problem if you mean when you try to make an espresso, it leaks out of the bottom where the water container meets the machine?  Have you gotten a fix?-   jennifershop
Solution #1
posted on Mar 02, 2009
Not Rated)
hair14
Rank: Apprentice
Rating: 0%, 0 votes
lost my instructions for descaling my delonghi espresso machine
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
the water coming out of the steam nozzle is clear but fromthe brew head it is milky looking. I have... (More)
Answer
How do you fit a new glass flask to a bodum coffee press? The fit is very tight and cannot get the... (More)
Answer
when we switch to steem to froth the milk it is not supllying steem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
