Question about Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire dryer (model GLEQ2152ESO) will not start and insists that the "door is not closed" I have pushed and closed the door every way I can. Is there a sensor that is malfunctioning? Thanks! Judie
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check the door switch... it may be broken...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 14, 2010
Model # GLEQ2152ESO will not start just humming sound when you push start button. Error code rE5
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Apr 13, 2015 | Frigidaire Dryers
My 2009 Frigidaire dryer door won't open
un plug the dryer for two minutes let it reset , then plug it back up. see if this helps you.
Feb 11, 2013 | Frigidaire Dryers
Fridgidaire electric Dryer model gleq2152eso display LOC and wont start.
Press option and select (button with lock) at the same time and hold for 10-15 seconds.
Jan 18, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Mar 01, 2010 | Frigidaire Electric Dryer
Doesn't start
first are you sure you have power to the unit?then if you do you could have an open neutral connection in the unit, the only fuse in these could be an electronic fuse on the control pad to protect the electronics on the circuit board
Sep 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Stacking Frigidaire Washer Dryers
no you do not need to put them on rollers. yes it would make it easier to service them but rollers would not be stable enough to keep the washr from shaking in spin cycle.
Jan 23, 2009 | Frigidaire Washing Machines
Frigidaire GLEQ2152ES Electric Dryer Logo
177 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
