Question about HP Officejet 5510 All-In-One Thermal Printer
"printer cartridge error"
All 3 green lights are flashing as per above. Machine will do nothing.
tried changing priner cartridge and no difference.
Plse help. I can't be inventingthe wheel here!
We've had this machine for 3 yrs now without a single problem.
  • 1,463 Answers
Hello rcdh
you can try here hp5510 or 5510 All-in-One
see if any these links will help you .
Posted on May 15, 2008
Whenever i turn my Canon BJC85 portable printer on, the green power light and yellow error light flash and 8 beeps are heard. The printer will not function in this state & the ink cartridge carriage is...
Hello, you can read the error codes here:
it seems to be a temperature error and cannon suggest that you replace the print head.
Removing the Cartridge ( Print Head )
1. Make sure that the printer is turned on, then open the cartridge cover.
2. Press the CARTRIDGE button to move the cartridge to the center.
3. Remove the BJ cartridge.
Let the machine be without the cartridge, close it, turn it off and back on, is the error still there? then redo the above and attach the cartridge to the machine, if the error is still there, try another cartridge if possible if the problem still remains, turn the machine off for atleast 15 minutes / unplug, then try again.
Jul 08, 2011 | Office Equipment & Supplies
Red light flash, E on dispkay
Well, I would take out the cartridge first.
And then wipe out the circuit part by rubbing alcohol (by QTip).
And try back.
Sometimes, by little bit of dust, cartridge cannot be recognizable in the priner.
If above method is not working, your cartridge must be shorted.
And need to replace with new cartridge.
Apr 08, 2011 | HP DeskJet F380 All-In-One Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    The red light is blinking and it doesn't print.
    There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
    1) Green On, Red Off = Printer Ready.
    2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
    3) Green Fast-Flashing, Red Off = Printer off-line.
    4) Green Slow-Flashing, Red Off = Processing Data.
    5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
    6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
    7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
    8) Green Off, Red Off = Printer power is off.
    9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
    10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
    So what is your printer condition? Better know what is going on your printer so can solve the problem.
    Oct 02, 2009 | Kyocera FS-920 Laser Printer
    My samsung ML2010 printer has Error button flashing green
    your printer is not inisilize properly. it is a logic card pls you can repaired it from printer vendor.
    Sep 02, 2009 | Samsung ML 2010 Laser Printer
    Hp lj 2500 flashing yellow light
    The yellow-print-cartridge
    light is blinking, and the
    printer stops printing.
     The print cartridge is
    empty or missing.
     The printer cannot
    detect the print
    cartridge correctly.
    1. Reinsert or replace the print cartridge.
    2. If the print-cartridge light is still blinking but the
    Attention light is not on, turn the printer off and
    then back on.
    3. If the problem persists, repeat the above steps
    with yellow print cartridges until the error is
    4. If the problem persists, replace the printcartridge
    E-label reader, which is located on the
    pressure assembly of the print-cartridge
    Jan 09, 2009 | HP LaserJet 2500L Printer
    Not printing green light flashing red one constant
    Here is the indicator light error page from the Service Manual
    You will see there is no specific error of "Power flashing" with "Error On". The inference is that the Power light was doing someting to cause it to flash (e.g. jn cartridge change mode) when something went wrong to cause the "power no change" with "red light on" error. The most likely I think is "no cartridge" - or more likely "faulty cartridge looking like no cartridge". Have you tried re-replacing the cartridge with yet another. Other possibilities are some sort of mechanical jam. Please report back on this.
    Dec 17, 2008 | Epson Stylus 680 InkJet Color Printer
    BJC55 Printer not printing
    There are some possibilities due to the above phenomena. Let's discuss about it:
    1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
    2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
    3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
    Hope these help.
    YBC (/\)
    Nov 01, 2008 | Canon BJC 55 InkJet Printer
    Epson C48 red and green lights flashing alternately
    Only Solution is Re-burn printer firmware.
    Mahesh DG, Pune
    Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
    Cannot get Canon PIXMA MP 150 to work at all
    salve la mia mi canon mp 150 lo scanner non funziona e mi da errore code 2,250,0
    Apr 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    HP Officejet 5510 All-In-One Thermal Printer Logo
    90 people viewed this question
    Ben Johnson
