Question about Xerox Office Equipment & Supplies
I have the xerox XRX-951L Laminator. It stopped advvancing the paper and now will not feed thru. It was making a buzzing sound but is silent now. What should I doi?
4 Suggested Answers
SOURCE: the lamination paper is stuck.
you need to use the carrier (cardboard cover) that the lamination paper comes with.. if you dont use the carrier your plastic will stick to the hot rollers... you will need to take it apart and clean out the plastic.. easy to dow hen it is cold peels off easily... pain in the neck getting it back together as the wires in the front interfere with the front screw post...
Posted on Jan 15, 2009
SOURCE: My Xerox XRX-8X paper shredder
WHERE DO I GET A DRIVE GEAR FOR MY XRX-8X PAPER SHREADER CHEAP.
Posted on Sep 03, 2009
  • 2072 Answers
SOURCE: The Xerox Faxcentre 2218 squeeks when receiving
Most likely it is coming from the fuser bushing. Leave the machine off overnight to cool. Open the right side door. You will see an assembly with a yellow sticker on it, it is a caution HOT warning. That is the fuser. There are 4 phillips screws holding the fuser in and one plug. Take those 4 silver phillips out, disconnect the one white wire. Lay the fuser facing the front ( as removed) towards you. You will now see 2 screws on the fuser. Remove and unfold the fuser. Not the ends of the charcoal gray, or black roller. There are 2 fiber bushings on the ends, they are beige in color. I would suggest taking some alcohol and flushing those out, then letting it set for a few minutes to day out. If you can get a high temperature lubricant, lightly apply some in the busking area, On the 2218 you have to apply it lightly because you dont want it seeping into the contact area of the heat roll. I suspect that is the squeak. it is very common on that fuser on that model. You can replace the fuser, but thats a pricey way to get rid of a squeak.
Posted on Jan 21, 2010
I have a xerox laminator and it will not feed
Unplug the machine. Then try to look, using a flashlight, if there are any obstacles that may interfere with the feeding. try to gently tilt the machine and try to remove any obstructions. If you can't see anything, try to force something through the feeding path and see if something is stuck in there.
If this doesn't work, them you might want to take it apart.
Nov 16, 2012 | Xerox Staples XRX-LM1910 Laminating...
How doses the plastic feed through the xrx lm1910 laminator
You will need to make sure that you are using the right type of plastic. also, is the plastic the right size? Also, you need to check if you are trying to feed at all. Are you able to feed the paper?
Jun 08, 2012 | Xerox Staples XRX-LM1910 Laminating...
The unit was heated up and when I insert the laminator pouch with the document to be laminated it does not feed. it just cooks the front edge of the pouch. do I need to let the unit cool and start...
Hi, there's a seperate switch for the moter on my laminator. After the device is heated up you need to turn on the switch, so the mechanism starts to pull in the pouch.
Mar 14, 2011 | Xerox Staples XRX LM1910 Laminator
The sheet im laminating rolled up inside, cannot get it out
Water-based cleaners will not work with this type of adhesive. Rubbing alcohol or a citrus-based cleaner (eg, Goo-Gone) will be required.
Feb 22, 2011 | Xerox Staples XRX LM1910 Laminator
I have a Lamiart-3201 laminator and the rollers are not working - or i cannot feed my item through the laminator. Usually I just put it in and the laminator feeds it out the other end...
Make sure your laminator is heated up properly before feeding material through. Usually, for a low-end laminator, you will wait anywhere between 10 to 20 minutes before it is completely heated up, allowing you to use it. There should be a red button that will tell you it is NOT ready yet, and a green button will tell you it is.
Nov 16, 2010 | Office Equipment & Supplies
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Xerox 5314 copier giving error code of u2
A U2 means the machine did not see the lamp scan. The lamp did not leave the right side of the machine. May be hung up on something, may have broken a cable the scan motor may be bad, I would first of all remove the glass and see if there is anything binding the lamp and keeping it from scanning. If you think it feels tight to move, that is normal on a 5314. What I am looking for is the lamp stopping not being able to move.
Mar 14, 2009 | Xerox Office Equipment & Supplies
Iron on transfers keep jamming
Make sure you have the size corrrect on the tray setting, if you have to you can create a custom size paper.
Also set the paper or media type to Heavy 2. Or heavyweight 2.
Dec 18, 2008 | Xerox DocuColor 3535 Copier
The lamination paper is stuck. never went thru the other side. How do I open it and un jam it? Please help ITS THE XEROX XRX-951L laminator. I couldn't find t n your list
May 26, 2008 | Xerox Phaser 8500/DN Printer
171 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
