Question about Gateway FPD2275W LCD Monitor
My GNR F173 makes a squeky noise when switched on and the screen goes black. After switching on again (several times) it works fine. Can this be fixed? Will it be worth the cost if it can?
  • gwyn1william Sep 13, 2010
    GNR not Gateway sorry new user!
  • 732 Answers
Gwyn1william, Monitor printed circuit components are all "working" !!!! That's good!! You need to see video clips at YOUTUBE!!! Learn how to do soldering. Then use very large magnifying glass or use inspection grade microscope (4x to 20x) to find the 1 maybe 2 "hairline fractured,thermally intermittant" solder connection of the leads of the devices (active or passive) which are causing this condition and will need to be resoldered. ($20 or less DIY) ($40 to $80 contracting out the work) Then and only then return to fixya and rate this as to it's usefulness to you in solving monitor problem. 12fixlouie
Posted on Sep 13, 2010
GNR TS902W monitor start up problems
GNR TS902 19 inch flat screen computer monitor with 3x4 aspect ratio
Difficult starting or completely dead:- (This is a 'Stock Fault' with these otherwise excellent monitors)
Check or replace the electrolytic capacitor C829 - type 1000MFD 16 Volt DC Wkg It sits on the PSU board next to an empty "C817" mounting point (which is for a device wired in parellel) so you can fit two smaller ones (of ~ 500MFD each) . . I suggest replacing it (C829) with a 1000MFD 25 VoltDC Wkg type.
Also (very much less frequently) capacitors C802 - 470MFD 50V VoltDC Wkg and C819 680 MFD 16 VoltDC Wkg are faulty.
Jul 08, 2014 | GNR 19M1 19" LCD Monitor
When i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this.
Hi there, I am also facing same problem with my Dell Inspiron mini 1012, when i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this. S Bhat, India
Nov 01, 2010 | Computers & Internet
Flickering screen
The flickering problem you have is caused by a failing power supply. There are parts called capacitors that are failing and causing the power supply board to put out pulsing voltages until it can stabilize. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you can soldethen you should be able to do the repair yourself. If you don't want to do the repair we offer a repair service for this unit. You can get details for that service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Jul 15, 2010 | Samsung SyncMaster 205BW LCD Monitor
Hi i have a GNR TS902W monitor it doesnt turn on
Hold down the left and right arrow buttons for 1 minute. The monitor should switch inputs and start behaving again. Mine did that although I never discovered what changed it in the first place.
Jan 01, 2010 | GNR 19M1 19" LCD Monitor
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
17" Sony Monitor Goes Black and No Light Shows On The Switch
Sounds like your backlight bulbs are wearing out.It is a common problem with Sony LCDs. Difficult to replace then.
Monitor Mike
Jan 03, 2009 | Sony SDM-HS73P 17" LCD Monitor
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
Aug 19, 2007 | ViewSonic VX910 19" LCD Monitor
How can i fix my portable dvd player?
that noise sounds like the focus is trying to see the disc as it has to focus to see or register there's a disc. Maybe the turntable slipped down a little or there's dirt or film on the lens. Good luck
Apr 26, 2006 | Durabrand 8.5'' Portable DVD Player
Gateway FPD2275W LCD Monitor Logo
131 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
