Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a craftsman lawn tractor automatic transmission model 917.275901. The tractor barely moves when I put it into reverse. It will creep forward when it is in nutural. There is no problem going forward. What do you think is wrong?
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 95 Answers
SOURCE: We have a 1 yr old Craftsman 24 HP lawn tractor
It sounds like the brake plate is sticking on the transaxle,if you look on the right side of the transaxle a rod and spring run back from the front to a plate,under this plate are two 1/4 pins that actuate the brake pads on the disc,lubricate these pins with wd-40 and move the plate back and forth to see i this frees the problem up.
Posted on Jul 30, 2009
mowerman1857
  • 389 Answers
SOURCE: need a wiring diagram for a craftsman lawn
http://c.searspartsdirect.com/lis_png/PLDM/P0502131-00001.png
This will take you to a wiring diagram
Posted on Sep 20, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
rockmeister
  • 2047 Answers
SOURCE: craftsman lawn tractor automatic transmission
Just like motor vehicles when transmission gets stuck on a particular place without moving forward or backward it is a sign of a jam in one of the transmission levers. This is usually caused by lack of transmission fluid in the gears.When the fluid or grease depending on what your unit uses gets low the levers begin to grind against one another and therefore bring about such problems as you are facing. Although there is an off chance that the problem could also be from the automatic selector in this case the damage might not be so much probably an electrical fault.
First get an expert to check the auto selector if it is in good shape. If it is then i am afraid the problem is from the transmission levers.
Hope this insight has been helpful?
Posted on Apr 14, 2011
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Husqvarna 42 inch cut with hydrfostatic ****** will barely move in forward or reverse
check the belt tension also if it sounds like a growling sound check the fluid level
Aug 20, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Transmission running eratic sometimes will only move in reverse. I have to move lever forward and back several time to get it to move forward.
You can try an air purge 1st. Instructions for this can be found in your owners manual. If that doesn't help the trans-axle will need replacing.
Oct 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor model 917.270821 ( Auto trans)
Check the fluid level in the transmission. If the fluid level is low, the trans will act as if it's slipping.
Nov 25, 2009 | Vacuums
We have a 1 yr old Craftsman 24 HP lawn tractor Model #917.28870 that sounds fine, but BARELY moves forward. It does move in reverse a bit more easily. It feels like the parking brake is engaged when you...
Jul 07, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mar 30, 2009 | Craftsman Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
121 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
