Question about Cuisinart DGB-600 Coffee Maker
How do i take the dgb 600 apart,to fix the leak?
  • 3,083 Answers
This web page talks about leaks and cautions against removing the bottom plate without a special tool:
http://forum.appliancepartspros.com/general-talk/5276-cuisinart-dcc-2000-coffee-maker.html
At the end of the blog, a fellow talks about some machines having security torx bits holding the bottom plate on. They're not going to make it easy to fix. This seems to be the hardest part of taking the machine apart, as there are not other explanations for the rest of the procedure.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 13, 2010
5 Suggested Answers
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
  • 6 Answers
SOURCE: DGB-600 grind & brew thermal coffeemaker
ThaMp3Doctor
  • 8596 Answers
SOURCE: Wattage of a Cuininart DGB-600
The consensus seems to be that it is 1025 Watts, although I have a hard time believing it - not even a stand mixer is 1025 watts.
Posted on Apr 04, 2009
  • 55 Answers
SOURCE: DGB-600 won't stop beeping and is missind grinder
check if theres a magnet sensor for the grinder cover if so place a magnet on it should poss stop the beeping
Posted on Dec 20, 2009
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
Coffee maker is leaking water
6300mobile restriction code send
Apr 13, 2010 | Cuisinart DGB-600 Coffee Maker
Cuisinart 14 cup coffee maker won't heat up. It turns on but no coffee is brewed. heat plate is cold and water stays in resevior. Is it worth fixing? Can it be fixed?
It may be. Unplug the machine and take it apart. Find the thermal fuse. It is usually on one of the power wires near the plate. Check it with an ohmmeter or continuity tester. Replace it if it is open (no continuity) I'm not sure if they still do, but Radio Shack used to sell the fuses.
Jan 07, 2010 | Cuisinart DGB-600 Coffee Maker
Apr 01, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart dgb-600 brew pause feature doesn't work
Replace the filter basket - they can be had for around $6.00 plus shipping - you can even get them directly from Cuisinart.
Jan 23, 2009 | Cuisinart DGB-600 Coffee Maker
Taking apart a Cuisinart DGB-600
I pulled it almost all the way open- towards back and used a flat screwdriver (or small philips that can fit in space from behind) and I pushed up a bit towards center and it came right off- don't worry- shouldn't break if you just ease it out of it base on either side.
Nov 22, 2008 | Cuisinart DGB-600 Coffee Maker
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
Jul 17, 2008 | Cuisinart DGB-600 Coffee Maker
Water leaking
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great! But I must say that i have seen better engineering in child's toys!
Aug 31, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
210 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
