Question about American Pro VS1405 Car Audio Amplifier
What size fuse does amp vs 1405 need? - American Pro VS1405 Car Audio Amplifier
How do i replace a fuse
Found out want size and amp, either pull it or if held in by screw , unscrew it.
Feb 02, 2015 | Cars & Trucks
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
What size glass fuse do i need to relace one in my warfedale 5000 amp
more than likely its a 30 amp fuse but if you look at the old fuse it should tell you the fuse size
Sep 19, 2014 | Audio Players & Recorders
What size fuse do i need on the positive side do i need if i have it hooked to the battery. my cb is a maxon mcb-40. if u cud tell me what size inline fuse i need it would help alot thank you
Most un-modified CB radios run about 2 to 4 amps on transmit. A 5 amp fuse is sufficient for most radios. Check you owners manual for the correct size fuse to use.
Feb 28, 2011 | Maxon Radio Communications
Am not able to get drivers for Thoshiba satellite 1405-S151 laptop
sanathanchan,
Here is the website for driver support for your model of Toshiba Satellite:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=191872&rpn=PS140U&modelFilter=1405-S151&selCategory=2756709&selFamily=1073768663
Hope this helps.
-S
Oct 19, 2010 | Toshiba Satellite 1405-S151 Notebook
What size fuse do I need on the power cord from the battery to the amp? thanks
It depends on the size of the amp. The best route to take is to purchase an amp installation that includes the power and ground cables, RCAs,remote turn on wire and...fuse holder with fuse. You choose the amp kit base upon wattage ofthe amp and they come in 0,4 and 8 gauge sizes.
Sep 23, 2010 | Legacy Audio LA930 Car Audio Amplifier
How can i connect my toshiba satellite 1405-s151to my wireless ho
switch on the wireless either by a switch on the thing it's self or by holding down the FN key (bottom left of keyboard) then pressing one of the F keys i.e F1,F2 OR F8 (top of keyboard) The one with the little wireless symbol on it.
Then right click on the little PC screen icon in the tray next to clock at the bottom right of your screen & select "view available wireless networks" select your WI-FI from the list then click the "CONNECT"button.
put in your (SSID) & (WEP or NETWORK KEY) when asked, witch you'll find on the back of your router, then tick the box to hide the key if it's not all ready hidden, tick the save & auto connect boxes then your done.
GOD LUCK if you get stuck let me know.
Jan 16, 2010 | Toshiba Satellite 1405-S151 Notebook
Size of fuse for Ultimate PA2204
O SO U JUS NEED LIKE A FUSE THAT IS ABOUT 20-40 AMPS
Mar 20, 2009 | Car Audio & Video
American Pro VS1405 Car Audio Amplifier Logo
89 people viewed this question
Top American Pro Car Audio & Video Experts
xxxxxx xxx
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
