Question about Maytag Dryers
Maytag gas dryer #ldg9806aae does not ignite.ignitor used to come on and fire up for 5 minutes then less & less now ignitor won't glow & coil on gas valve is hot to the touch!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired. You can test it for continuity between its two pins, no continuity means bad fuse. If this is fine then you?ll need to check the thermostat, igniter and coils. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
I have a gas dryer that the igniter plug glows, but does not light the gas. One time when I had the front panel off the gas ignited and the dryer heated, but only burned for a minute then shut off. Now I...
with front off it will short cycle. If ignitor glows and then goes out without lighting, you have bad burner coils. The 2 black round things on burner assembly. Unplug unit then unplug coils and remove bracket with 2 screws. install coils and test.
Aug 27, 2010 | Dryers
I have a Maytag Nepyune dryer model# MDG4000BWW. The drum turns, the ignitor glows but the gas does not always ignite. When the ignitor is glowing, if I wiggle the wire going into the 2 prong coil, I here...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
How to check the igniter (continuity?)
If there is power to the ignitor and it does not glow the ignitor is bad. If it does glow,place a clamp on amp meter over one wire of the ignitor and turn the circuit on. If the ignitor reads less than 3 amps,replace the ignitor.
If the ignitor glows and registers 3 amps or more you must check the flame sensor for correct operation. If the ignitor and flame sensor are both good,replace the gas valve coils.
Oct 31, 2009 | Maytag MDG7600AW Gas Dryer
There is no heat on Maytag gas drier. I see the ignition glowing but no fire. But some times the fire starts for one minute, then goes off. I am not sure of the model # below,
If the ignitor is glowing, the problem is most likely the gas valve coils. These electrical coils are located right above the gas valves. When energized, these solenoids open the gas valves and permit the burner to light. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at the same time if any are suspected of being faulty. Hope this helped and best wishes.
Aug 10, 2009 | Maytag MGD6300T Gas Dryer
Dryer's flame cycles but will not burn
Check the following to address this issue..
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 01, 2009 | Dryers
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Dryers Logo
90 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
