Question about Maytag 25.1 Cu. Ft. Bottom-Mount Refrigerator - Black
This is the second time last time I was without a refrigerator for one month now the ref and freezer do not work and door got extremely hot I had to unplug. This happened last friday service will be this wed Sept. 15 and they told me they will have to order a part another 7 bus days I am a senior on a fixed income I did my shopping the first week of Sept. I had to throw everything out that leaves me with no food for the rest of the month. do you realize how hard that it. I saved for years to buy this and it has turned into a nightmare. I should have kept me Sears Refrig I had for 20 years no trouble. You have to help me with this second time I have had no food in the house.
  • 3 Answers
SOURCE: Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Posted on Aug 20, 2007
22yooper
  • 828 Answers
SOURCE: Refrigerator and Freezer not getting cold?
The compressor is located in back of the refrigerator behind a removable panel at the bottom. But you indicated frost buildup in the freezer near or at the bottom which tells me your compressor does operate. Frost indicates a problem in the defrost system. This type of problem can be caused by a bad defrost heater, defrost thermostat, or defrost timing device. Call an appliance repair for service.
Posted on Jun 28, 2008
kevin000
  • 1847 Answers
SOURCE: maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Posted on Aug 10, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Posted on May 28, 2009
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
SOURCE: my refrigerator and freezer is not working too well. it stopped getting cold and then i transferred the food to the refrigerator in the garage and unplugged the kitchen. about a week later i plugged i
i have a maytag two door fridge it's not working the fan is working but it's not getting cold fridge or freezer can you help me sometimes it tries to cut in makes some kind of sound for a couple of sec and stops again
Posted on Jun 15, 2009
Section between refrigerator and freezer extremely hot.
Check your owners manual troubleshooting. See if you find an answer. Please be more specific. Sounds like it's "stuck" in defrost mode, since it uses electrical heating elements to make the freezer coils melt ice off, but only lasts long enough to remove the collected ice. I would guess the unit runs constantly, or cannot maintain temperature. If the defrost cycle is not working there is a timer not working, or relay, or somehow a very rare short in the defrost system.
Feb 18, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Post between freezer and refrigerator doors is hot
I have seen a programme on TV which showed a cable between the doors which over time with constant opening and closing became worn. I should contact the manufacturer.
Apr 21, 2012 | Samsung RS2630SH Side by Side Refrigerator
"Hi, I have a questions
It seems you will need a service technician again. Be sure you got a warranty if you agreed to service your refrigerator. If you use the refrigerator correctly it will never go bad for less than a year and call for service repair. But if you definitely used it correctly, chances are the refrigerator you brought have a factory defect.
I hope my advice help you.
Jun 15, 2011 | Refrigerators
My ref. is only 4 months old and I just realized that the bottom freezer is not freezing and the icecream is maelted. The door wasn;t open. Help!!! Heidi
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 09, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
May 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Feb 13, 2008 | Refrigerators
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag 25.1 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
16 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
