Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
MFC-440CN printer displays "Low temperature". Room temperature is normal.
Soulvisitor
  • 1113 Answers
SOURCE: MFC-440CN ink purge
Menu/Set, Black Start, Menu/Set, and Black Start keys very quick thats maintence mode now enter in or arrow to 76 set then purge area and type need to be sected set... 99 to exit
Posted on Dec 22, 2007
  • 16 Answers
SOURCE: how to connect wirelessly mfc-440cn printer
Hi!
I checked and this printer is not in itself a wireless device. This means you will need some sort of "wireless router" to plug the printer into.
Go to your favorite electronics store and get a decent wireless router. Linksys is a good brand and reasonably priced. You'll also need a small section of network cable to plug into your printer and into the wireless router.
Once you have this set up, you'll be able to take your laptop or other wireless device and "see" the printer on the wireless network.
Good luck! Don't forget to rate the posts!
Posted on Aug 08, 2009
bolinlamar
  • 157 Answers
SOURCE: brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Posted on Sep 04, 2009
  • 62 Answers
SOURCE: how do I network brother mfc-440cn printer - what
  1. Plug the printer into a computer on your network.
  2. This computer must be on and remain on for the printer to work.
  3. Add this local printer to this computer in "Control Panel" - "Printers".
  4. Now share the printer.
  5. Go to another computer on your network.
  6. Add this printer (as a network printer) to this computer in "Control Panel" - "Printers".
  7. The system should find the printer and add it...
Posted on Nov 15, 2009
cns assoc
  • 677 Answers
SOURCE: Brother MFC-440CN USB Printer double prints letters
Did you use Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine.
When they see it’s Generic Cartridges, it will print lines thru the words, mis-align the letters & put stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
MFC 440CN machine is displaying the wrong date / time and I can't find a way to reset it in the manual.
If you go to the last menu item, called INITIAL SETUP the Date/Time is in there.
You can then change the date using the number pad and the OK key.
Jun 13, 2011 | Brother MultiFunction Center MFC-440CN...
I have a MFC 440CN brother printer, but not work . the screen have problem 50 and I donot have manuaal
Hi
For the MFC -440CN manual please click the mention below link: --
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002183/Mini3_MfcLcdW_UkEngUsr.pdf
May 08, 2011 | Brother MFC-440CN InkJet Printer
Keeps saying Low Temperature and wont print
based on the error, the surroundings of the printer is too cold. The room temperature is needs to be raised.
its too cold for the printhead to print, if the error continues, than most likely the printhead needs replacement.
Jun 05, 2010 | Brother MultiFunction Center MFC-440CN...
I have mfc 440cn. Do I need to replace the drum?
The MFC-440CN does not have a drum.
The only consumables this printer has is ink cartridges.
These wil need to be changed when they are empty.
Thanks,
Pat
Apr 07, 2010 | Brother MultiFunction Center MFC-440CN...
I need printer CD
You don't have to order a new one, for drivers for your MFC-440CN printer just open this link http://www.bioticaindia.com/mfc-440cn.html
Jan 26, 2010 | Brother MultiFunction Center MFC-440CN...
Brother MFC 440CN pick up wheels only work about
take q tip and dip in alcohol with printer off clean paper wheels let dry completely. Your printer should be okay then. Make sure you do not drip any alcohol inside the printer and that the printer is off and unplugged.
Jul 11, 2009 | Brother MultiFunction Center MFC-440CN...
Will not fax
how do i find my fax number on my mfc-440cn?
Sep 09, 2008 | Brother MultiFunction Center MFC-440CN...
Share printer
First you have to set up a home network between both your computers, once that is established run an networking cable to your printer it should all be ran through a networking hub so all machines can communicate with one another
Jul 05, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
95 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
