Having colored spots on screen. Changed the bulb with no change,I replaced it with the same bulb it came with from the factory. what else could it be?
  • Johnny Avery Sep 13, 2010
    This is for a Panasonic PT-52LCX15
  • 10,594 Answers
I need to know model number and brand info of your tv to understand possible cause of problem.
Thanks.
Posted on Sep 13, 2010
  • Shahid Electronics
    Shahid Electronics Sep 13, 2010
    OK, color spots is problem of light engine as it has 3 lcds inside and few UV filters that got bad and light engine will be replaced to fix the issue.
    It would be costly fix done by experienced tv repairman.
    Let me know if you have additional question.
    Thanks.
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Oct 08, 2015 | Sony Televison & Video
Brown spots
brown spot on the screen
the dust on the top of the LCD panels,
need to clean the LCD panels
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | Dukane ImagePro 8039B LCD Projector...
I changed the bulb on my epson powerlite 83+ and now there is a blurry spot in the middle of my screen. Is there anyway to fix this?
For anyone that may still stumble on this post, we have two of these and the blurry spot is most likely caused by the neutral density filter in front of the Green LCD element. We still haven't found a source for this part, but it seems to be caused when the bulb overheats and melts the plastic filter causing it to warp and wrinkle.
Jun 09, 2012 | Epson PowerLite® 83c LCD Projector
I have a blue spot on the corner and the edge of the screen.
the problem you are having is with the optical block sony had a recall for this but I am pretty sure it has ended you can call sony tech support and see
Jan 25, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Hitachi 60VG825 projection TV is 3 years old. For the past several months the screen has been turning blue around the outer edges & this past week a large yellowish green spot the size of a...
Sounds like Calibration is needed on the projection internals. Your TV uses a rear-projection system and the problem is either in the imaging LCD Unit or the light filter. I see in a previous thread you have changed the bulb. You can invest in a voltage regulator to keep the hardware in factory condition.
Also you can burn a DVD of a stuck pixel remedy video and run it on the screen with full brightness and full contrast. This is used for plasma burns and stuck pixels on conventional Flat panel TVs but can repair color issues with projection systems. This therapy is focused on the imaging unit between the projector and the main drop of your tv.
please feel free to post a more in-depth description or any changes
Nov 06, 2009 | Hitachi 60VG825 60 in. LCD Television
I have 62 DLP rear projection
Bad Color Wheel is my First thoughts,Light Tunnel, But if Spots begin to appear Then Light Engine.
Sep 19, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
Movie mate 30 brojecting blue spots on screen
it's the light polarizer on the blue lcd panel. it's fried due to excessive dust and heat. unfortunately you'll have to replace the optical engine.
Sep 04, 2008 | Office Equipment & Supplies
HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Jan 05, 2008 | HP VP6121 Multimedia Projector
Panasonic dlp tv
buy the ee prom color correction tool. This is a small electronic color wheel chip reprogrammer. It costs approx.$100. but the only thing it is a difficult tool to locate. Check google for ee prompt correction tool for a parts number and call your local store.
Nov 23, 2007 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
