Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Light on- motor running- not cooling in freezer or frig- should we consider repair- what may be the problem- thanks-
  • 58 Answers
It depends how old this refrigerator is it could have a leak in the sealed system and that is a quite costly repair.
Posted on Sep 16, 2010
Hi we have a GBS22HCPABB fridge and the motor runs, frezzer works but fridge will not get cold just stopped
you have a few possibilities 1. a defrost problem restricting air flow from freezer to ref. 2. a bad freezer fan motor 3. a damper issue not opening to allow air to flow from freezer to frig. most all refrigerators generate the cooling from the freezer to the frig via the freezer fan motor
Mar 06, 2010 | Refrigerators
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The motor is on but its not cooling. The light is on, I can hear the motor running but the ice has melted and it does not feel cold in the freezer or cool in the frig.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fkjf
Sep 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge is not cooling but freezer is fine
Yes ! in most french door bottom freezer units there is a fan in the freezer behind the back panel that supplies air to the freezer as well as the frig. When the DC motor on the fan wares out the rpms reduce to the point that the volume of air supplied to both components is reduced to a point that the fan will support the freezer but not the frig. The price of the fan motor alone is around $80.00, if all of the components for the fan are replaced the parts will run about $200.00, if you are not going to do the work yourself it will probably cost in the neighborhood of $300.00 parts and labor.
Jul 12, 2009 | GE PDS22SBRLSS Bottom Freezer Refrigerator
The freezer is cold, but frig will only go down to 41-43 deg rang
Make sure both condenser and evaporator fans are running. Is it possible that you might have something blocking the air flow from the freezer to the fridge?! Can you hear the fan running up on top?
Jul 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
Help frig not cooling model # FRT21LR7A
You have to replace the electrical components on the side of the compressor. The heat from the fan not running by the compressor more than likely has damaged them. These are a safety feature to save the compressor from damage when it overheats.
You can find the factory repair manual here. This will have all the part numbers and what you need to replace to take care of your refrigerator. The Top Freezer Refrigerator one will be about your machine. It covers all the FRT Models.
Thanks
Jan 08, 2009 | Refrigerators
Fridge freezer not working but lights on
Our new 10 day old top frig/bottom freezer stopped freezing, then the top refrigerator stopped cooling, but the light was working and you could hear some motor running and an occasional "clicking" sound. One internet blogger adsvised unpluging the appliance for 1/2 hour. Another advised 2 hours. Then plug in the appliance and see if it started cooling/freezing again. Our experience = nothing. We called the repair folk and the new frig/freezer had a failed compressor and a broken timer!! We were not thrilled. Suprisingly the store we bought the ap[pliance from gave us a $50 gift card to compensate for the lost food. They didn't have to do that - so ask for it; can't hurt.
Aug 03, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
