Question about Jandy PHP High Head Pump 2 HP Up rated
Jandy Stealth 2.0 tripping GFI after heavy rain. Been a week since storm.
    Novelist:
  • 116 Answers
Very possibly a bad GFI. GFI's are cheap and worth replacing if in question. also might try hooking up directly to another source and see if it trips a breaker
Posted on Sep 18, 2010
Recent rain storm, water came out from failed baffle, the power did not trip the circuit, but the unit no longer power's up?
Depending how the unit is installed..you may have a ground fault type outlet up in the cabinet someplace. Maybe on top of the cabinets. This will cut power to the unit without tripping the breaker. Just find the outlet & reset the GFI outlet. Fix the leak.
Mar 01, 2016 | Kobe Brillia CHX191 Series 30-inch Under...
I have a Jandy stealth series pump and this morning it was not running. The breaker was tripped and when I reset it and turned it on the motor only hums for a few seconds and then the breaker trips...
This sounds like the motor has seized up. You will most likely need to replace at least the motor and maybe the complete pump assembly.
You can take the pump into a local motor shop and see if they can rebuild the motor for you.
US Parts Center
Aug 21, 2011 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
Outdoor electric recepticle GFI tripped (I'm guessing during recent rain) and will not reset. Would this indicate faulty GFI or something wrong in system. This was installed about 2 yrs. ago and has been...
if the outlet was wired right and working fine before -- then ' yes ' the GFI has tripped and it could have failed do to the rain. replace the outlet with a new GFI outlet and I would also suggest that since you have the outlet outside that you install it into a outdoor weather proof outlet box.
c...
Jan 18, 2011 | Lutron SCR-15-GFCI-SW Satin Colors 15A...
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
GE XL44 Broiler/Self Clean Trips GFI
This should be a 220 volt appliance so I'm trying to figure how this was connected to a GFI. Does it have a second connection to power the controls?
Most GFI uints I have seen are not rated for large amounts of power consumption. I used to throw the one in my bathroom if I was running the electric heater and the wife fired up the hair dryer.
I'm wondering if this indeed does require the additional 110 connection then it sould be pulling heavy current from it to aid in the cleaning process. I've never seen a stove that needed the extra. My old electric range had only the 220 as well as my elders.
So if that is the case then you should not be running that through the GFI outlet because of the heavy drain will heat the breaker in the GFI and cause it to trip. Breakers actually work very similar to how the old fuses work. Heat causes the switch to throw. GFI units have a lower tolerance (designed to detect shorts quicker to save your life) and trip quicker than breakers do.
Apr 02, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Jandy PHP High Head Pump 2 HP Up rated Logo
222 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
