Question about Hampton Bay 36 In. San Marino in Brushed Nickel Fan
HAMPTON BAY SAN MARINO MODEL 666 834, FAN WORKS BUT NOT LIGHT. THREE WAY SWITCH. WIRED CEILING BLACK TO FAN BLACK, WHITE TO WHITE, GROUND TO GREEN, CEILING RED TO FAN BLUE.
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
Cerfer39
  • 709 Answers
SOURCE: Wiring a Hampton Bay ceiling fan
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
Posted on Nov 30, 2007
bigg t
  • 640 Answers
SOURCE: 2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Posted on Jan 17, 2008
aborcass
  • 2651 Answers
SOURCE: Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Posted on Apr 03, 2008
SOURCE: Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Posted on May 22, 2008
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
Tip
Fan speed switch wiring
If your are replacing the fan speed switch on the Hampton Bay San Marino mfg # 67353, this is the correct wiring pattern...L-white, 1-yellow, 2- blue, 3-black. I have been searching for this answer for 2 days. Thought I'd post for others with the same problem.
on Jun 01, 2008 | Hampton Bay 36 In. San Marino in Brushed...
No wiring diagram with fan ( hampton bay three speed fan with light)
white to white, black to black, blue to red, & green to ground.
If you don't have a second hot house wire(red), then put black & blue from fan to house black.
Nov 29, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black,...
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Nov 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Lights are out
The manufacturer is King of Fans. Their number is 800-330-3267.
Nov 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Hampton Bay San Marino 36" Ceiling Fan
18 gauge is a little light... should use 14. Are you sure it is a hum, or is it possibly the fan resonating due to imbalance of the blades. Watch to see if the fan is oscillating when it runs. Also, does changing the speed affect the frequency of the hum. If this is the case, you have to balance the blades using metal shims.
Sep 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 36 In. San Marino in Brushed Nickel Fan Logo
405 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
