Question about Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW
How do I defrost my freezer - Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW
    Master:
    Sergeant:
  • 449 Answers
Unplugg it
Posted on Sep 14, 2010
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
Freezer coil inside freezer box loads up rhyme ice preventing air flow. If I defrost the freezer it will work fine for a few weeks. I suspect there is a defrost timer, or humidity control that isn't...
There are three parts to all defrost systems.
1. Defrost Heater2. Defrost Timer3. Defrost Thermostat
Without a model number I could not look up a diagram or part numbers. I very seldom see a bad heating element. Most common is a bad defrost timer, second most common is the defrost thermostat.
Aug 02, 2011 | Sub-Zero Freezers
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Our under the counter freezer will not cool below 28 degrees. What are your thoughts?
Hi.
Try doing a defrost. If the freezer works after defrost, then it was the defrost system. If the freezer has auto defrost (evaporator comprising thermostat, timer, fan and heater), then the problem may restart after few days. In that case the problem is one of the parts comprised in the evaporator.
If the freezer does not cool after defrost, then temperature control (depending on model) may be responsible. Compressor and gas leak usually result in no cooling at all.
Regards.
Ginko.
Feb 11, 2011 | U-Line Freezer Origin Series 75FB 6 Cu....
Defrosted a Crosley freezer, have water draining from door
ITS RARE BUT NOT UNUSUAL,its only condensate from the surrounding room collecting inside a cold door frame,if you dont defrost it at least twice a year,you will loose efficiency.
Jul 05, 2010 | Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer doesnt freeze and red light at top came on
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Freezers
Freezer is on and just stopped working
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW Logo
55 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
Tom Chichester
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
