Question about Royal Office Equipment & Supplies
The PCUA # is 291139E & the other # is PX70MX. When I push the power switch, the shredder does not turn on. What can I do to fix this problem?
    Genius:
  • 1,218 Answers
If the machine does not run at all even in reverse then you have possibly lost the pcb inside...give Royal a call at 1-800-524-0799 for parts assistance.
Posted on Oct 09, 2010
My Royal Crosscut Paper Shredder, Model # PCUA:16326H-FE will not turn on. Is there something that I can do?
Paper shredders have a main switch and a couple of safety switches, the first of these is the one buried in the slot so the cutters are only moving when sheet paper is inserted and this switch has a very light return spring and flimsy linkage that easily jammed with paper scraps or easily displaced or sometimes it gets broken. The other switch prevents operation unless the unit is standing squarely on a container. Now my shredder is a few years old the unit has to be repositioned a couple of times before the latter switch engages.
The units benefit from being taken apart periodically and the buildup of dust and paper sraps cleaned out and maybe a brief spray of a dry lubricant around the moving parts.
Jan 02, 2017 | Royal Office Equipment & Supplies
How do I remove paper stuck in my shredder????I have a Royal 10X Cut Paper Shredder. On label it has PCUA:29054E 10x 00324040. How do I take it apart to remove the wedged paper???
You may have to turn it upside down and go to work with tweezers and a utility knife to remove every bit of paper from the mechanism. I have found that 10X rating to be overly optimistic; the equivalent Royal shredder I am using currently groans and complains if more than a few sheets are fed in at a time.
Feb 22, 2015 | Royal Office Equipment & Supplies
Fellowes Paper Shredder PS-79Ci power switch not working -- will not turn on!
Have you looked at the shredder blade to see if anything is still there? Turn power off, check shredder blade, clear anything stuck, put back together, turn power on and try again.
Mar 05, 2014 | Fellowes Office Equipment & Supplies
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
I have a 10X confetti paper shredder model # PCUA 29054E. When I put the paper in it shredds spuratically. It will shred then stop then continue then stop completely. If I back it up it might continue but...
Lubricate the machine....put shredder oil onto a sheet of paper and shred it...do this a number of times to get the oil down into the cutting blades... x-cut shredders should be oiled regularly.
Mar 18, 2010 | Royal Office Equipment & Supplies
I need a gear for shredder AG15x. Part number is
For parts and prices call Royal at 1-800-524-0799.
Feb 10, 2010 | Royal AG15X Shredder
Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Aug 02, 2009 | Royal VF1012mx Shredder
Royal shreader pcua-29053u Damaged Gear
call royal spare parts department at 1800-222-2310 they will ship you a gear for about $6 + shipping
Apr 16, 2008 | Royal 10X Shredder
56 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
