Question about Cell Phones
My iphone 3G 's wireless wi-fi doesn't connect. it doesn't work. help please
    Problem Solver:
  • 6 Answers
It may be possible that you don't have that as part of the data plan call your service provider to be sure it is part of your plan.
Posted on Sep 13, 2010
I want to locate my wi fi password for my iphone.
I am assuming that you are trying to connect to the internet using the built in wifi instead of the 3G. To clarify, iphones don't have passwords for wifi. Wireless access points and wireless routers are the ones that have passwords. If you want to connect to the internet using an access point or router you must get the SSID of the router or access point and also the encryption and password to join said access point or router.
Once you have this information go to your iphone and select the settings icon. Then select the Wi-Fi, then turn on the wi-fi (if it is off), then under choose a network select "Other" and then type in the name (which is the SSID), tap on "Security", select the encryption that matches your access point or router (wep, wpa, wpa2, etc) tap on "Other network" (on the top left hand corner) to go back to the configuration page, and then type in the correct password.
Once you have done this your iphone will automatically connect to the access point or router whenever it is in range and connect to the 3G when it is out of range of the access point or router.
Hope this helps.
Aug 03, 2011 | Computers & Internet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Can you surf the web on an Apple iPhone without a Wi-Fi connection?
There are two nation-wide cell networks that allow you to browse the internet. The EDGE network (for original iPhone) and the 3G network (3G is faster, but not as widespread and can only be accessed through the iPhone 3G ). iPhone monthly plans include unlimited use of the internet, without using up your calling minutes.
If you can take advantage of a nearby wireless hub, you'll have much better speed than when you're on a cell-phone data network... but even without wireless, you can still browse, email, work and play via the EDGE or 3G cell-phone network.
Dec 12, 2010 | Apple iPhone 3G
How to use wi fi in iphone
Go to Settings > Wi-Fi and turn Wi-Fi on.
A list of networks that are in range will appear.
Select the network you want to connect to.
If the network is unsecured you will be connected.
If it is secured you will need to enter the key or password.
You will need to get the key from the person or business that owns the Wi-Fi network.
If this helps please vote for my solution.
Sep 03, 2010 | Apple iPhone 3G
Can i config iphone 3g safari to only use wi-fi connection. i.e. stop it from automatically using my carrier network 3g if wi-fi is not available.
my nokia c6-00 join viber app on wi-fi very well when i deactivate or have no wlan 3G connection is enabled and i serf on web very well with 3G but viber stop working..it says: No connection try again...can u explasin what to do please?
Sep 09, 2009 | Apple iPhone 3G
Cannot connect to the itunes store i must connect to wi-fi network to acccess the itunes store in order to download music. and i also dont know how to sync. and what is wi-fi
wi fi is wireless networking.  It requires the Iphone to be connected to a wireless router or access point to access Itunes on your phone via the internet.
You should reload Itunes to resolve the connection problem with your computer.
Nov 12, 2008 | Apple iPhone 3G
Wi-Fi 3g
Your iPhone will automatically switch to the WiFi setting if it is there! No need to turn off the 3g it will use your WiFi 1st, and 3g 2nd!
Aug 01, 2008 | Apple iPhone 3G
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
