Question about LG LSC27910 (265 cu ft) Side by Side Refrigerator
Sticks water does not stop - LG LSC27910 (265 cu ft) Side by Side Refrigerator
Hi. I has lg refri sometimes water keep running none stop .Do you know what wrong? Thankyou...
Posted on Dec 02, 2010
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Model # 110.26832692 does not stop filling up with water when the load selector size is set will overflow if I don't stop it!
Good luck, i hope this helps to figure out what is wrong with your washer,
Gene
Aug 05, 2011 | Kenmore Washing Machines
Does not stop filling up with water
Gene
Aug 01, 2011 | Kenmore Washing Machines
Water continues to run. Will not stop when machine is in the wash cycle.
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Washing Machines
The water runs in the tub but never stops. Even if you put it on spin to run the water out. The water never stops till it runs over the top of the tub. Is that something in the main control timer that is...
Gene
Jul 29, 2011 | Maytag HAV2557 Top Load Washer
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Water dispenser sticks open on model TFX25ZPBEWW
If you unplug the WR57X10026 Twin Water Control Valve on the rear of the refrigerator near floor will the water flow stop. Then plug that back in and unplug the refrigerator doest the water stop? I need to find out if the water control valve on the rear of the refrigerator is leaking while turned off or if the dispenser control board is sticking with the power turned off. Your model comes with 2 different choices of water control valves.let me know Thanks, Sea Breeze
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water level will not stop at medium
You have a sticking water level switch caused by a blockage in the hose or pressure chamber, or a sticking inlet valve..
If it is a valve, then water would keep on coming in even though the washer is off, if this is the case, then fit new valve..
If it is the level switch you will have to unblock the hose and and chamber.
Hope this helps.
Jan 01, 2009 | Maytag Performa PAV2200
LG LSC27910 (265 cu ft) Side by Side Refrigerator Logo
265 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
