Question about GE GSS20IEP Side by Side Refrigerator
Freezing up The coils in freezer are freezing up ice all over the coils fridge not getting cold .I defrosted coils and replaced thermostat, it did the same thing after about a week.
  • Anonymous May 31, 2008
    We have a JennAire french door style refrigerator that froze up about 6 months ago. The repairman replaced the control board to the tune of $450. Last week the same thing happened. The refrigerator is about 3 1/2 years old and can't fathom spending another $450. Any suggestions?
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 14, 2008
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
Bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Nov 16, 2009 | Kenmore 21.9 cu. ft. Bottom Freezer...
Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Oct 28, 2009 | Refrigerators
Frig gets cool but not cold, freezer cold, won't freeze
Oct 26, 2009 | Jenn-Air Refrigerators
Refrigerator freezer is not freezing,ice accumalates on one side of the back wall
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle
Sep 16, 2009 | Refrigerators
Fridge won't stay cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Refrigerators
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
GE GSS20IEP Side by Side Refrigerator Logo
168 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
