Question about Kenmore Oasis HE 27082 Top Load Washer
Wash machine will run for about ten minutes and then will start beeping and flashing F51
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa and I am sorry to hear whatever happened. Error
F 51 flashes when there is a motor rotor position sensor (RPS) failure. Please follow the step by step instructions to resolve this issue: This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this step failed.
2. Unplug washer or disconnect power.
3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
4. Remove the console to access the machine/ motor control assembly.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6. If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to step 7.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
What does a flashing F51 code mean?
Dump the appliance. sears delivers the worst garbage available
Mar 22, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
Electrolux ewf1074- cycle time flashing and beeping and not running cycle
Consult the manual first, if there is no troubleshooting , contact your dealer (thinking about the warranty term)
Dec 02, 2017 | Electrolux Washing Machines
My kenmore elite oasis he top load washer keeps stopping in the wash cycle, beeps and flashes a code F51...what does this mean?
from what i can find out it apears to be the rotor position sensor which seem to be a common fault it apears you need a new board to fix the problem
Aug 14, 2011 | Kenmore Washing Machines
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
E3 error
looks like a heater failure it statrs to heat at about this time into wash mode.
Nov 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
228 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
