Question about Homelite Mighty Lite Lawn Trimmer
Trimmer won't start. I pulled the spark plug out and put a little gas in and then it would start. I then let it set for 10 minutes and it started right up again. Went to mow and trim about an hour later and it would not start again so I did the same thing buy putting a little gas in the spark plug hole and it started right up. I noticed the spark plug tip was very black when I took it out both times
  • Homelite Master
  • 7,482 Answers
The black on the spark plugs indicate that the fuel mixture going to the engine from the carb is too rich...needs adjustment...
Check your fuel filter in the fuel tank,if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 05, 2010
Hedge trimmer , mod.040090D 40350. Won,t start.. I pulled the plug, grounded the plug body, a spark should be seen at the plug gap., but instead a spark is seen from the plug body to ground, what would...
You will see a spark jump from the plug body to ground if it isn't tightly grounded to the engine. However a spark should also jump the gap in the plug at the same time. It can be difficult to check a plug this way because it tends to bounce around the place when pull starting the engine. You could try getting a bit of wire and clipping on end to the exhaust or fin on the engine with a crocodile clip, clothes peg or vice grips. The other end of the wire could be wrapped around the threads of the plug and held with a clip.
Fore more tips on starting a hedge trimmer see:
http://fixofile.host56.com/tips2.html#tip2
Nov 24, 2011 | Craftsman 22" Gas Hedge Trimmer
Craftsman 32cc gas trimmer ran a couple times this season, then will not start. Changed plug, new gas mix, cleaned filter and spark arrestor. No luck. Pull cord is hard to pull in the first foot or so,...
Pull the spark plug and hold the side against the engine while pulling the string. check to see if there is a spark you may need another person to help. Was the air filter oily when you cleaned it? If so you might need to remove and clean the carburetor.
Jun 07, 2011 | Craftsman Garden
I have a Husq. 326 L trimmer; my pull cord seems to tug and becomes almost unpullable and it wont start; I have a new spark plug-what could be causing this?
Pull your plug back out and see if your cylinder is full of fuel, if this is the case your needle/seat is leaking fuel into cylinder causing hydrolocking (gas won't compress) good luck
May 02, 2011 | Husqvarna 28cc Gas Line Trimmer
Need to know what carb screw adjustment need to be set at weedeater starts for about 4-7 sec then shuts down put new hoses on checked gas filter and cap checked out ok. i pump the ball about 10 times...
If there is a choke adjustment you should set that at full until the trimmer warms up, don't touch the gas. Then repull start at half choke, don't touch the gas either at this time. Then start at no choke, and then set your idle on the carberator with the adjustment screw. Also don't push the primer bulb so many time you will cause the spark plug to get flooded and drown out the spark, which is exactly what is happening.
Sep 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Wont start what is spark plug gap whatelse bulb full,new,gas in it,lines hooked
These are bad about flooding with the least amount of trying to. I usually can get mine started by letting it sit for 5-10 min. push the bulb 3-4 times hold the trigger and push the choke on full with 3/4 speed set. Pull 1x. Don't worry usually it won't start on this setting, it really just helps get the choke and carb set. Put choke back 1/2 way and try to start, if so, gas the trigger a couple of times but not holding in down. If it don't start put the choke on full again and try to start without holding the trigger. It should start after this. Take the plug out replace the coil wire onto plug and pull the cord gently to see if you're getting spark at the plug. Holding the coil boot to prevent it giving a small jolt.
Jul 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Ryobi 30cc was running ok and then cut out. Not been able to re-start since
First check vent in fuel cap to make sure it is not clogged, then check to see if fuel filter inside the tank is obstructed or if fuel intake line has softened and is possibly collapsing...pump primer bulb and see if it is sucking gas into the carb...next choke engine and try to start...if it doesn't start pull the spark plug to see if cylinder is getting fuel...if so re attach plug to the plug wire and ground plug to cylinder head....pull start handle and check for spark at electrode of plug....or put a little gas in plug hole and re-install plug ....pull starter handle a couple of times and if engine starts and runs for a second, you have spark....Your problem sounds suspiciously like your carb has ingested some trash and is clogged which will necessitate a good cleaning and re-tuning...possibly a rebuild...Hope this helps... ;-D
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
GAS TRIMMER WON'T START - BUT ALMOST STARTS WHEN I POUR GAS IN THE SPARK PLUG POCKET, THE GAS THERE DRIES/DISAPPEARS FAST. MUST BE A GAS LINE SITUATION? WHAT SHOULD I DO?
The gas is going into the the crankcase. When the piston goes down it opens the ports and allows the gas to go down untill it could fill the crankcase. Start by blowing compressed air into the spark plug hole and allowing the piston to go to it's lowest position. This will usually remove any liquid gas from the crankcase. Next get yourself a small spray bottle and fill it with the same gas mixture your trimmer uses. Now you can spray a small amount into the spark plug port, replace the spark plug, full choke and pull till it pops. set to half choke and pull. I have also sprayed into the carb but you must open the throttle to allow the gas to enter the combustion chamber. Spray,close throttle,pull choke and pull. You may need to do this a few times for it to start. After it starts let it run at half choke for awhile until it warms a bit then open choke and go to full throttle. If this dosen't work it's possible to have other problems.
Apr 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
New TB70SS used one hour run great started easy. Following week started on run fine for 10 minutes it became sluggish and died. Has not started since. Yes new gas correct mix. check spark arrester for...
If the trimmer is new and giving you these problems, then take it back to the retailer and either trade for another one, or pay a little extra for a 4 cycle. The 4 cycle is a little hard to start too, but will run out perfectly and no more mixing of oil.
The higher price tag is well worth the time, effort and aggrivation experienced versus a 2 cycle engine.
I hope this helps.
Jul 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Cannot start my trimmer, even change the spark
Take off the air cleaner and squirt gas in the carb. If it fires it is not getting gas from the tank. If it does not fire pull the spark plug and squirt a little gas in the cylinder. Replace the plug and try starting it. If it fires it is not getting gas from the carb.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
