Question about Maytag Refrigerators
I have the top/bottom model. 7yrs old. The fridge is on but not very cold. The freezer is cool & keeps ice solid but will not freeze meet or frozen veggies. Fan will not turn on. The fridge was turned off at one point and vaccumed any dust. I ran the ice maker 3 days in a row which I normally do not. And then one day it quit making ice and from then on does not get cold. It reminds me of my car air cond/it needed freeon. Does it sound similar?
  • 6 more comments
  • kmunoz40 Sep 13, 2010
    Do I have to pay 7.00 dollars to questions reqarding your solution?
    Can i purchase a motor fan on my own and where?
    Will do. Im so excited with plan B. Wow you make it sound so simple.
    This is a wonder service. I just can't see spending money when its only 7yrs old.
    Lets cross our fingers.
    karen M
  • kmunoz40 Sep 14, 2010
    I went an purchased the fan motor this morning and my husb will install this eve.
    I have no comp at home so you'll get the results tomorrow.
    You just know how comforting this service is having some info to go on with an applience
    so large. I can't afford the service and I can't afford a new fridge so this will be the answer to
    my prayers. I can't thank you enough. At least I know i tried something myself instead of thowing in the rag.
  • kmunoz40 Sep 16, 2010
    Im doing the Snoopy dance on my toes!!!
    Your solution was the answer to my problem.
    Thankkkkkkkkkkk Youuuuu so much!!
    I will never ask anyone for their help except "FIXYA"!!
    What experts! Wow.
    You need to advertise more!!!
    from the bottom of my heart/thank you!!
    karen m.
    karen..m........
    mission accomplished thanks to "fixya"
    applause!!!!!
    karen m.
    Thank you FixYa for all your info and time.
    The motor worked and I am so grateful for your service.
    Applause guys!!!
    karen m.
    Your service is like having you standing next to me telling me exactly what and how to solve the problem. If I had the day off I would have had the problem solved in a few hrs.
    This service should advertise across the sky!!!!
    Thank you!!!
  • 3,083 Answers
I could be a bad control board, relay, fan, or poosibly thermostat not turning the compressor on, or you're right, the compressor could be a little low on freon. Here is a general troublshooting aid:
sxs
-refrigerator-side-warm-then-cold-then-warm.html">http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/18808-maytag-plus-sxs-refrigerator-side-warm-then-cold-then-warm.html
You might have two problems- a faulty water supply valve, and whichever problem is not turning on your fan. Here's an icemaker troublshooting site:
http://repair2000.com/icemkr.html
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 15, 2010
  • Tom Carson
    Tom Carson Sep 16, 2010
    If you enter your model number at the following site, they will have diagrams and parts lists to assist you: http://www.appliancepartspros.com/
    Enter the make and word "support and parts" and you will find some options for your fan.
    Sorry I didn't respond earlier, and good luck!
  • 6,927 Answers
Remove the inside panels of the freezer and the fan,the fan most likely has gone out,replace it,and after removing the inside panels of the freezer,look under the evaporator coil and see if the drain is frozen.If so melt the ice with hot water from the sink,until it is clear,food debris stops the drain up from crumbs and such,then the water can not drain so it freezes,this is water from the defrost on the coils,it is on a timer.If the timer is stuck on,then the coil will be warm to touch,and the drain will not be frozen.Make sure the drain is good and clear,water from defrosting the drain will end up overflowing the drip pan under the unit.When this has been done and it is back together,set the setting to a warmer setting in the freezer,this diverts the cold air to the fridge compartment,and still will allow the freezer to freeze.Then set the thermostat in the fridge compartment to a colder setting.Allow over night for the unit to start showing a difference.The ice maker will take a while to regulate.
Posted on Sep 14, 2010
    President:
  • 1,796 Answers
Hi!!
Unplug unit form wall outlet, remove the Ice maker and freezer back panel, unplug electrical connections from the fan and remove it. Using a heat gun or hair dryer to defrost the evaporator coil on the back of the freezer, make sure the water line going to the Ice Maker and air duct going to the fridge part of the unit is free of ice. Use some towels to soak the water from the melting ice. replace old fan motor with a new one, reinstall back panel and ice maker, plug unit back into wall outlet and make sure the freezer fan is working.
The freezer fan makes cool air circulate thru the unit, if it becomes inoperative, the evaporator fan will freeze up and fridge part of unit will get warmer.
Keep me posted! If you need additional help just post a comment.!
Posted on Sep 13, 2010
  • 3 more comments
  • Rene J Solis Sep 13, 2010
    No Sir. Will give you all the assistance you need to get your unit working. Feel free to ask any questions.
    Yes you can buy it at any appliance parts store and many hardware stores. You'll need the units model number. You can call the store in advance to make sure they have it in stock.
  • Rene J Solis Sep 14, 2010
    Hi!!
    If you need help installing the fan motor, just let me know.
    I am pretty confident that the fan will solve the problems you described. I expect to hear from you tomorrow saying your fridge is working fine. Good day. Thanks for using FixYa.
  • Rene J Solis Sep 16, 2010
    I am glad your problem is solved! Thank you for using FixYa!!
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | GE Refrigerators
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Freezer is cold... fridge is not
Could you pull it away one more time and feel the compressor to see if cool, warm or too hot to hold your hand on. That tells me a lot of things. I want to see if your compressor is shutdown, running but not cooling or trying to start and cannot. That will help me to answer what we need to do next. Sea Breeze
Aug 19, 2009 | Refrigerators
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Cold box at the top of the fridge
This box is the evaporator which provide cooling for the whole fridge. They will only freeze things solid that are easy to freeze. Don't count on it being like the normal freezer.
Nov 12, 2007 | LG GC-151SA Compact Refrigerator
Refrigerators Logo
155 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
