Question about Samsung Digimax D53 Digital Camera
Wont show the screen
My camera turns on, but then says low battery or doesnt show the screen even though it has new batteries. Also the lense is sticking out and wont go back in.
  • 3 Answers
You cant use regular batteries on these cameras. I have the same one., you need to buy rechargeable batteries or lithium batteries, both are stronger,but more costly than your regular alkaline batteries. This will defrinatly fix the problem..I am 100% positive,.They sell recharg- able batteries ar walmart for like $20.00 taht comes with 4 aa batteries and the pulg in charger.
Posted on Jul 08, 2008
Wont turn off
Getting out your battery is ok. Don't expect the lens to retract, because the camera has no power. But after you reinsert the battery, the lens should retract, because the camera knows in what position the lens is.
Be sure the battery is in good shape. If the battery is not fully charged or even worse, when it is defective, noting will happen. When you have a multi meter, you could check the voltage of the battery. It should read a little more (few tenths of a volt) when measured with a multi meter. if it is only slightly less then what is printed on the battery, you can assume the battery is defect. The camera will not work with a defective battery, so in that case you should replace the battery.
Nov 11, 2013 | Samsung TL500 EX1 Digital Camera
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
Conon powershot A450 lens error
Try to use fresh batteries, and push the barrel in and out when it turns on to see if the 'binding' of the focusing gear can go away when you do this manipulation of the barrel.
If the error continues, maybe the camera needs service by Canonusa.com.
I could not, unfortunately, find a reference for an a450 on the website, though. Is that an older model?
Jul 29, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
It wont stay on. when i press the power button the led light blinks red. the camera is off but the lens is sticking out
It looks pretty much as battery problem, try using a new and charged one. Low charged (bad)battery can do strange things to eletronics
Oct 12, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
Apr 28, 2009 | Canon PowerShot A470 Digital Camera
Camera wont turn on batteries are new
I had the same problem that the green light turned on then the red one, even though the camera batteries where new.
I found a solution for this problem, hope it works for all as it did for me.
http://www.sendspace.com/file/ysolwv
The link shows the images of the steps you need to follow to fix this problem.
This problem actually is from low batteries or low voltage in the camera, but its not because the batteries are dead, it is because the batteries don't have a good contact with the metal conductors in the camera.
In the images you can see that the camera has a plastic cover for the battery contacts, so the way to fix it is to remove that plastic cover with a small screwdriver, and pop in the new batteries.
With that it should fix the problem. Hope it works.
Jan 02, 2009 | Kodak EasyShare C533 Digital Camera
Low battery display
i had a similar problem...my lense woudnt go back in either, but it kept saying low battery and bleeping. I realised that my lense was stuck skwint, and that was what was causing the problem, once i straigtend up my lense it folded bak into the camera and worked fine wen i turned my camera on :D
May 06, 2008 | Samsung Digimax D53 Digital Camera
Canon powershot doesnt work at all now!
Most probably weak batteries (this can happen even if new batteries are used). Recommend rechargeable NiMH batteries for the A400. See the following:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Mar 31, 2008 | Canon PowerShot A400 Digital Camera
Samsung Digimax D53 Digital Camera Logo
97 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
