Question about Maytag Dryers
Dryer wont start dryer started smoking last used now wont start has power. door switch checks fine. has power to start switch
  • Maytag Master
  • 8,220 Answers
That sounds to me like an air restriction has caused overheating.
The blower wheel on these dryers tends to start slipping with age. dryer wont start
dryer started smoking - 528f0fa.jpgThe slipping makes the dryer over heat and cause the safety's to shut down quickly.1b3c53edryer wont start
dryer started smoking - 32276fa.jpg= 32276fa.jpgThis takes a lot longer for the clothes to dry. Finallydryer wont start dryer started smoking - 61b049c.jpgopens and kills the whole thing. To service it 9d5ebcf.jpg61b049c.jpg
Was this helpful?
Posted on Sep 13, 2010
Dryer wont turn on
Lots of things it could be. I'd try the shut-off switch first.
There is a switch that is supposed to turn off the dryer when you open the door.
That switch is often made of plastic, and can break or even fall out inside the machine.
After that, I'd check the start switch to see if it failed.
Be blessed.
Feb 17, 2013 | Crosley CDE6000 Electric Dryer
Kenmore dryer wont start tab broken
Yes that is the lever for the door safety switch. It can be fixed easily,
I have repair pictures and home made video on Kenmore dryers HERE
Dec 02, 2012 | Kenmore Dryers
I need help. Our dryer control currently works and when we push and hold the start button it doesn't start. lights work on control panel. door switch works and power is fine. last time it was used it smelt...
maybe the motor for the dryer, is this a even heat? if so here is a website:
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
if not an even heat here is another website:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer wont start,
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 24, 2009 | Bosch WTMC652SUC Gas Dryer
Valh my dryer model fer641fso wont start when i push the start button it does this low beeping sound bought brand new only owned for 5 months worked fine all day yesterday stopped working last night.
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly. OR The start capacitor may have failed and i would not suggest you deal with that as they give out a nasty electrical charge, also check and clean all filters and check your user manual for further advice as your machine should still be under warranty, call the numbers listed in your manual. good luck
Jul 19, 2009 | Frigidaire Electric Dryer
Estate dryer wont engage
Check the following--
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Wont start, power to all parts, is there a reset button?
There is a wiring diagram on the access panel on the back, or in the control head.
Follow the path from incoming power through all switches and leading to the timer.
I suspect either the door switch or start switch has failed.
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool le5800xkno
Did you turn the machine off for 5 minutes and then restart it to see if it resets the system?
Oct 10, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
132 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
