Question about Whirlpool Cabrio HE 4.5 cu. ft. Washer
My washer has an error message LD on the screen and all the lights are blinking. The load seems to be half way through (towels are still soapy). I can't get it to unlock the door and pressing power or start does nothing. HELP!!!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
Ld Message
Hi
An LD error indicates long drain time which means that there is either something stuck/clogged in the pump or the pump itself has gone bad and should be replaced. You can take it apart completely and check for impeller damage or clogs. You have to clean it completely so make sure that you have lot of towels ready as there will be water coming out of it when you clean the pump. Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | Kenmore 22422 Top Load Washer
Ld message
Hi
Daniel
Sep 05, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
We got the LD error code and then nothing. We have no lights no response from machine. Checked outlet and plug-there is power going to the machine.
Hi
Daniel
Sep 05, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Oasis is beeping with an error code of Ld
LD code is long drain,one of two things the drain pump is frozen and need to be replaced or there is somthing in the pump.Pull the washer away from the wall a bit and get a bunch of towels.Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio HE 4.5 cu. ft. Washer Logo
129 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
