Question about Sharp AL-1655CS Copier
I have a Sharp AL 1655c saying add paper then press start to resume, but there is paper in the tray. Help!!!!!!!!!!!!
4 Suggested Answers
  • 53 Answers
SOURCE: Tray 1 is full on my Sharp AL-1642CS but when it ties to print to tray 1 the 'P' keeps flashing!
pull both trays out.....have a look in tray 2, is there a switch sensor actuator hanging down yes........is there a similar one in tray one?
No? They get knocked off and lost very easily
Posted on Jul 19, 2008
  • 7 Answers
SOURCE: "Load Paper" screen wont go away. Is loaded with paper!! Help!!
hi does the machine give you any error codes?
is it both trays that are not working or just 1?
Posted on Dec 06, 2008
  • 2072 Answers
SOURCE: "P" is blinking in display Sharp AL-1641cs
There is a small white gear that drives the fuser module. It wears out at 30 to 40 thousand pages.
If the sound is a jumping to gringing noise that would be the problem.
That gear jumping will cause the machine to say out of paper,, jam,, give all kinds of problems from things bouncing around.
Posted on Aug 02, 2010
My Sharp AL-1655C makes a knocking noise when I turn it on, how can I repair this?
more than likely it is the fuser section the gear sometimes breaks and causes the knocking sound.
Jan 20, 2015 | Sharp Office Equipment & Supplies
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
The printer is showing a "p" on the display. what does this mean?
The "P" means that you need to add paper into the paper tray or in the manual feed tray. Odds are that you are getting a paper jam from the paper tray? I would try to fill the paper tray with paper & make sure the copier is on a level surface. You may need the paper feed tire's or you may have a paper present sensor broken? I would just use the manual feed tray. Good Luck
Oct 17, 2010 | Sharp AL 1631 Copier
I have a Sharp AL-1642CL printer. It will not
Check the paper tray sensors or change the set to external by pas tray to paper tray.
Jul 14, 2009 | Canon imageCLASS D320 Digital Copier
I have a Sharp SF-2022 copier and it flashes a U6 code abd will not work. How do I fix this?
u6 is sually something to do with the papaer tray or feed section check to make sure the tray is set properly and that you have the guide plates set correctly and that the tray is fully set
Jun 11, 2009 | Sharp AL 1631 Copier
"P" is blinking. There is no paper jam. Paper is not feeding from the paper tray.
Hello sir; there is paper pick up roller dirty or worm, need to clean or replace.
Apr 28, 2009 | Sharp AL-1451 Laser Printer
Jun 11, 2008 | Sharp AL-1642CS Copier
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Sharp al-1250 wont switch from tray 1 leter to tray 2 legal when printing
On the control panel there should be a button that either says paper select or looks like a bucket with lines in press this and the machine will change paper trays.
Thanks J
Dec 11, 2007 | Sharp AL-1250 Laser Printer
Sharp AL-1655CS Copier Logo
182 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
