Kenmore 65942 Electric Dryer Logo
Posted on Sep 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer is no longer getting hot, I can only find a serial number, therefore having a hard time looking up my unit. Serial #MT0514392
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Sep 14, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10836767
Points
101584
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dryer heating element are they interchangeable
The elements are usually not interchangeable. You can use a website like appliance parts pro to look up both units by model number to see what the elements look like. They usually have diffferent mounting hardware or the enclosure might be different, some mount to the back wall and others mount underneath the drum.
2answers
Kenmore electric dryer stock# 65701 S# F54023394 Model# 76570110 How old is it?
Mentioned here at the bottom
https://www.shopyourway.com/questions/1041116
and
What year was my Kenmore dryer made? To determine the age of your appliance, use your serial number (not model number) to find date of manufacture. Our serial numbers begin with two letters followed by six numbers. The 2 letters at the beginning of the serial number tell you the month and year it was made.
How old is my dryer by serial number? You can determine the age of your appliance by looking at the serial number on the nameplate. The first number indicates the year of manufacture, and the second and third digits indicate the production week. For example, 13500016: week 35 in 2001.
How can you tell how old a dryer is? To find the age of your appliance, use your serial number, not the model number. There are two letters followed by six numbers in our serial numbers. The first two letters of the serial number tell you when it was made.
What is the serial number on a mini Rae 3000 for.
Hello, Jeff -
A serial number for ANY series of a manufactured item identifies each individual item. A serial number can be just numbers or a combination of numbers and letters. Each serial number is unique.
https://en.wikipedia.org/wiki/Serial_code
(Quote)
Serial numbers identify otherwise identical individual units with many, obvious uses. Serial numbers are a deterrent against theft and counterfeit products, as they can be recorded, and stolen or otherwise irregular goods can be identified.
(End quote)
Therefore, the serial number on a Mini RAE identifies that particular hand held volatile organic compound monitor.
Best wishes.
What year was Kenmore dryer 110.66112500 made
Carter,
You can go to the following website and enter the info requested at the bottom of the page and it will give you the date of the dryer. You will need both your model & serial numbers. The manufacturers do recycle their model numbers about every 11 or 12 years, so you may get a range of dates.
Appliance411 Service How old is my appliance Age finder date of...
One thing that you can check, look at the exhaust hose coming out of the back and make sure that it is not kinked in any way and if you can, pull the dryer out and make sure that the hose is clear of any blockage. Usually when you have longer drying times it caused by poor air flow.
I have a Frigidaire Gallery W/D set. The model number for the washer is GLWS1339CS1. I need to dryer model # and the sticker is missing. Help?
Hi Joshua, I am happy to assist you!
I understand you are seeking the model number of your Frigidaire dryer because you are in need of the replacement part number of the heating element. Each appliance has its own model number listed in the serial tag on the unit itself. If the serial tag is missing or no longer visible on the upper front as you open the door of your dryer, at this point I would recommend reaching out to the manufacturer to verify if they have any documentation or your product registration. Best regards - Z
1helpful
Doesn't get hot, runs fine no heat
It is possible that the heating element has burnt out or a high limit switch (safety device to prevent overheating) has gone out. Element is located at the bottom of the dryer on the oppisite side of the exhaust. Looks like a toaster coil. Any break in the coil and no heat. New elemenrts can be purchased at an appliance parts house with the serial and model numbers for your unit to ensure correct part.
Dave
1helpful
I need a radio unlock code for a 1993 honda accord
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code (some people say that they have found the code on a sticker inside the glove compartment, but I wouldn’t count on that). Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release. The serial number will come up in two sets of numbers.)
Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number (or you can remove the unit and get the serial number from the back of the radio). Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Here is the URL for the Honda Owner page. If you register (no charge) you are able to get radio codes using the VIN number of your car, the serial number of your radio, and the
Phone Number and Zip Code that you give them when you register.
https://www.ahm-ownerlink.com/login.asp?page=%2Fprod%5Fhome%2Easp
Hope this helps you with the process.
1helpful
How can i encode the radio serial number to the sterio of my honda civic 2001?
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.)
. Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
hope this gets you started on the process.
3helpful
3answers
I have a original full version of nero 7 essential but i have lost my serial number therefore i want a serial number to install nero essential 7. please help me
name: Bush - Neron 2007
comp: Baghdad - Rome 2007
serial: KC89-1080-1964-MAXX-4006-3200-811M
or: 1C89-K0CA-1961-M2AX-4011-2XXA-M715
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
