Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My washer is working on the cold setting and the HOT setting, but when I set it to warm, it doesn't work...only COLD water comes out. What could be the problem?
  • 2,272 Answers
In some cases the connection get reversed.Not always necessary but in some cases. The hot and cold water supply lines running into the back of your washer are probably reversed. In other words, the cold water supply line coming out of the wall is probably hooked up the the hot water connection on the back of your washing machine and the hot water supply line coming out of the wall is hooked up to the cold water connection on your washer. Make sure you TURN OFF the water supply lines before unscrewing the hot and cold water supply lines where they connect to the back of the washer and reversing them. If you don't turn off the water then you will have a flooded room when you disconnect the supply lines from the washer.If that is not the case,then check the hose and fill valve connected to the water passing line.If there is any kind of blockage then this can be the issue. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 13, 2010
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Only the hot water works
r u sure the cold water is getting to the washer if so u have a cold water solenoid and thats where your problem is probably gonna be it should have 2 wires put it on cold and turn washer on and check to see if u have power going to the solenoid if so and u have water gettin to the solenoid the solenoid is bad its a simple changeout and quite cheap
Feb 25, 2010 | Kenmore 98702 Stacked Washer/Dryer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I DON'T GET WARM WATER, WHEN SET ON WARM, ONLY GET COLD
If the setting is only hot and cold, there will be no
warm water coming out. At warm setting if it is
present, it should give you warm water.
Sep 23, 2009 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No cold water on cold settings
Try switching you hot cold inlets to the washer on the back....If that doesn’t work let me know...
cbinny1
Jan 04, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
