Question about Samsung HL-T4675S Television
My lamp is good. How much is a ballast for a samsung HLT4675SX
  • 5,081 Answers
The ballast will cost around $70.
Check this link below:
http://www.discount-merchant.com/SAMSUNG-4422-400-03765-3-p/1186767.htm
Posted on Sep 13, 2010
Samsung hlt4675sx/xaa lamp ballast keeps going out
Hello Leeann,
Wow 3 ballasts is too many too quick. Did this solve you problem every time?
Have you checked the voltage going to the ballast? this might be a power supply issue. The power going into the ballast should be between 320V - 380V. Please do not try to measure the power going to the lamp! The ignition charge can be 15kV and it is dangerous to you and a multimeter.. please let me know and I will try to help you get to the bottom of this
Jan 06, 2014 | Samsung HLT4675SX/XAA OEM TV Lamp
BALLAST PART No FOR A SAMSUNG SP50L6HX PLEASE HELP
Google that model number with ballast or lamp ballast to locate the part and its number. Usually the color wheel will not operate if ballast is not working---Lamp comes on and stays on the Ballast is good.
Nov 06, 2012 | Samsung SP50L6HX 50" DLP HDTV
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Bulb will not come on . I replaced with new one & still wont come on.
Sounds like the ballast is at issue, If you have the correct lamp for your ballast. Samsungs are very critical that the lamp be matched to the ballast, often replacement lamp dealers dont take that into consideration when substituting samsung lamp numbers. Was the lamp a samsung lamp or a generic replacement?
Jul 20, 2011 | Samsung Televison & Video
Samsung DLP HL-R5667W lamp won't fire. Changed lamp & ballast and still won't work. Fans are working fine, color wheel good. Lamp door switch good. When I power on, I hear ballast buzz like it's trying...
Was the replacement lamp the same part number as the original as there are different arc gaps for different lamps and the wrong arc gap will cause the lamp not to light. Since the ballast is powering up the lamp should light if the baalast is matched to the correct arc gap of the lamp being used.
Nov 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung hlr5667w that won't turn on. Good lamp and ballast
Any light blink on the front. Whats the voltage to the ballast from the power supply. Common problem on these sets are bad lamp door switch. Try shorting the switch. Color wheel also is problematic but usually will be noisy and cause shut down. Check power board for swollen capacitors. Hope this helps
Nov 03, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
2004 Samsung DLP HLN-507W1X:Flashing lights
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
Sep 21, 2009 | Samsung Televison & Video
Samsung hln4365w no powerup flashing lamp & temp. can i repair myself & where do i get parts?????
There should be a lamp code sticker on the left side of the tv.bp96-00224c or bp96-oo224a are the part #'s for the 2 lamps used on this set,but you need the right one or it will blow prematurely because of 2 different ballasts used.
Aug 22, 2009 | Televison & Video
Ballast on samsung hlp4663w
The transformer can't damage the new lamp. Faulty transformers normaly take out the driving transistors or the fusible link in the power supply, if these are good then just replace the lamp. Espacially if you know the lamp is bad (test it by swapping with the others if unsure)
May 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HL-T4675S Television Logo
305 people viewed this question
Jerry Greenberg
Jerry Greenberg
