Question about Honda Black Max 3000 Psi Pressure Washer
What size o ring does a black max BM80913 - Honda Black Max 3000 Psi Pressure Washer
Cannot attach any of the nozzles
if these are the original fittings ,most case would be the o-ring ,it has swelled change them and you'll see normally 3/8 or 1/4 inch
Sep 16, 2013 | Honda Black Max 2600 PSI Pressure Washer
How can i install the java game if it says that my *.jar file was over max size?
Sir!
Go to your phone settings and open up the application settings, then there is a option of max file size or something like that then open that option and change it to max size what ever you want. otherwise use the files which are compatible to your phone.
Thank you
Mar 29, 2012 | Samsung M3510 Cell Phone
I have oil in the muffler and when it starts there is alot of white smoke.
sounds like the piston rings are worn, and oil is seeping past them.
Try putting redex in with the fuel to see if that helps (might help clean the system).
Failing that, pop into Halfords and by a can of ?? (can't remember the name, but it's designed to take up the wear between cylinder and rings)
Hope this helps.
Jul 07, 2011 | Honda Black Max 3000 Psi Pressure Washer
"jar file is over max size" show, when install
It seems that the programm you try to install is to big for your mobile. Try to free some space on your phone but if it still doesn't work it must be because your mobile simply can't handle such a big programm.
May 10, 2011 | Samsung SGH-E251 Mobile Phone - Black
Bushnell banner elevation maxed out
It sounds as if your Scope rings are out of alignment or the front ring is lower than the rear ring. You may be able raise the bottom of the front ring by inserting a shim under the front ring base.
Aug 08, 2009 | Optics
Max size of cylinder
The biggest bore would be 1mm over.The standard bore on that bike is 65.0mm
so you could bore up to 66mm and to be a 900cc you would need a bore size of 68.5 mm
So your answers
  1. Yes, it can be bored
  2. No,Not to a 900cc
  3. Piston size is 66mm (making it roughly an 843cc)
I Hope this has answered all your questions,But please feel free to ask any more if needed.
Please take time to rate this fixya
Mar 18, 2009 | 1985 Yamaha XJ 700 X Maxim
Brother MFC8840D only 4 rings before fax pickup?
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
Sep 15, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Honda Black Max 3000 Psi Pressure Washer Logo
146 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
