Question about Cartier Roadster W62016V3 Wrist Watch
I need to change the date on my Cartier Roadster (back 2 days). How do I do that?
  • 831 Answers
Thank you for contacting FixYa.
  • Pull the crown of the analog/date Cartier watch and rotate it clockwise or counterclockwise until you see the date advance in the display window at about 1 a.m.
  • 2 Use the quick date set method by rotating the crown counterclockwise after reaching 1 a.m. until the hands reach 7:30 p.m. Then again rotate the crown clockwise back to 1 a.m. Repeat the procedure until the correct date is displayed.
  • 3 Adjust the date forward or backward 12 hours if your Cartier watch changes the date at the noon hour.
  • Best regards. Jewel
  • Posted on Sep 14, 2010
    What is the acceptable power reserve for cartier roadster?
    Cartier Roadster W62041V3 SS Watch Black Dial
    you have thousands of dollars to throw away on a watch and you come here for free advise??,go to a jeweller
    May 25, 2015 | Cartier Roadster Stainless Steel Automatic...
    Authenticity
    most likely when you see this but the only real way of knowing is to get the back removed
    Apr 17, 2014 | Cartier Roadster Mens X-Large GMT Watch...
    How do I change time on Cartier Roadster wristwatch
    Www.userguide.cartier.us/horlogerie/roadster/s+chronograph++rubber+strap+model/mht_2-time+setting
    Nov 06, 2011 | Cartier Roadster W62016V3 Wrist Watch
    Roadster not winding properly?
    Since the watch has a quartz movement, no winding is needed.
    If your watch has stopped, return it to Cartier to have it replaced.
    (to see their web site entry for this watch, go to http://www.cartier.co.uk/#/show-me/timepieces/w62016v3-roadster-de-cartier-watch-small-model .
    Jan 17, 2011 | Cartier Roadster W62016V3 Wrist Watch
    I haven't wear my cartier for a couple of days and is nor working i wear it for a few hours but still not working what should i do?
    Hi , your Cartier is a quartz movement watch and does not need to be winded or worn in order to work. It does though need a battery. This sounds like your battery has died and needs to be replaced. Any jewelery or watch repair store will be able to change it out from the price of 8 -20 dollars please only go to an experienced jeweler though.
    Oct 18, 2010 | Cartier Roadster Ladies W62026Y4
    Cant restart my cartier roadster chronograph. havent been using it for a couple of days and the movement wont start. please help
    If the watch is quartz its a cell replacement,use a watchmaker on a watch of this value.If its an automatic watch then you may be looking at a repair/service.A watch of this quality needs regular servicing at 4 years or so as lubrication drys.For work of this nature you will need a specialist watchmaker try www.rolexrepairs.co.uk
    Aug 16, 2010 | Cartier Roadster Chronograph White Dial...
    I have a problem pulling out the stem to set the date on my Roadster. Can you help? I can't seem to grasp the stem securely enough to pull it out. Thank you
    mcdevito 75 here, you should be able to get a finger nail just under the stem to lift the stem to set the time, day/date, first be sure the stem isn"t a screwdown type, gasp the stem and turn it to see, if it is a screwdown type, simply un-screw the stem then pull it out to set the time, day/date. If all fails your local or any jeweler can help.
    Jun 16, 2010 | Cartier Roadster W62016V3 Wrist Watch
    Cartier Roadster strap change
    Scanned from the handbook. Hopefully this helps.
    Aug 16, 2008 | Cartier Roadster W62016V3 Wrist Watch
    Changing the date
    It should only go to one direction, you might have a memory with some other watch for going both direction otherwise the way the internal dial works for cartier it should only go to forward, some manufacturer make the dial moving both ways but for quality watches such as cartier it goes only to one direction.
    Nov 07, 2007 | Cartier Roadster W62016V3 Wrist Watch
    Cartier Roadster W62016V3 Wrist Watch Logo
    3,088 people viewed this question
    Top Cartier Watches Experts
    k24674
    john h
    Are you a Cartier Watch Expert? Answer questions, earn points and help others
