Question about Garden
How much do I water after the roundup is applied
  • 5,129 Answers
Roundup (glyphosphate) doesn't get watered in. However if the area was stressed due to heat or dry conditions, water before using the Roundup to ensure that the plants are growing and transporting nutrients to the roots. The usual recommendation is 1" per week. Roundup kills all plants that it is in contact with. Then let the product dry before it rains (1-4 hours depending on the formulation read the label for rain-fastness information).
Water the plants that were not sprayed as you normally would as long as the treated areas will not be wetted before the Roundup is dry.
Even the extended control version does not need to be watered in.
If you are using a different product that needs to watered in, please read the label for directions. (For example some pre-emergents need to be followed 1" of rain to water them. Alternatively you can do a shallow tillage of the treated ground (2" deep iirc).)
I hope this helps.
(any directions given in the product label should be followed)
Posted on Sep 13, 2010
Does it make a big difference if i use a weed eater before applying round up?
Since Roundup works by being absorbed by the foliage and transported to the roots, I would think that cutting back the foliage would hinder this process, so you shouldn't use the weed eater before applying the Roundup.
Jul 27, 2011 | Roundup "" Weed & Grass Killer
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
How much round up PRO do you mix per gallon of water
It depends on the amount of active ingredient you need to kill the plants in your property. The rate is dependent on the size of the plants. For a final concentration of 1/2% (plants under 6" in height - do not mow them short the day before spraying), you need 2/3 oz of Roundup Pro (not the Roundup Pro Concentrate). However, if your area has perennials that are larger (stressed or 1-2 feet tall), you might need 2% Roundup, and then you need 2 and 2/3 oz of Roundup Pro.
Please read the label for your product and identify the plants in your location to get the appropriate rate.
Many Monsanto product labels are available as PDFs here: http://www.cdms.net/LabelsMsds/LMDefault.aspx?manuf=23&t= .
Do not mow or disturb the plants for three days after spraying. You may need to apply the Roundup in 7 days to get any plants that you missed (or weren't affected by the first dose). Wait another 3 days after the second application before planting in the area.
I hope this helps.
Apr 23, 2011 | Roundup "" Weed & Grass Killer
I recently used ROUNDUP on a lawn The product did its job, the weeds are gone, so is some of the grass near the spray. It has not rained since the spay went on - maybe 10 - 12 days. How can I restore the...
Your grass is probably dead as well. Roundup is a non selective herbicide and will kill anything green. So take care when applying. Even green stems of young trees. Shield from spray when spraying. The best is to plant new grass. Roundup stays active in the soil for around two weeks despite what Monsanto says so add new topsoil when laying new runners or a new block of grass. Rain is no issue except within 6 hours of treatment. You can water the lawn with no problem now. Good luck and take care-Roundup is a poison that does affect our hormonal balances especially women.
Aug 04, 2010 | Roundup "" Weed & Grass Killer
How much roundup to 1 gal water forwatering can use
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 29, 2010 | Roundup ScottsRoundUp 0394560 PT...
How to mix roundup to kill weeds
May 02, 2010 | Roundup ScottsRoundUp 0394560 PT...
Quantity of Roundup weed killer to spray 140 acreas of crop land
This 2.0% glyphosate is ready to apply at a rate of 3-10 gallons per acre That's 420-1400 gallons per 140 acres. Some weeds need a higher concentration than 2%. Most farmers buy 41% glyphosate concentrate, determine the number gallons of spray mixture their equipment will deliver, determine the concentration of glyphosate they need and mix the concentrate with water accordingly.
Apr 01, 2010 | Roundup "" Weed & Grass Killer
How much roundup to 5L of water so I can spray
If you're using pro-roundup or agriculture level roundup mix 1 Cup of roundup to 5 gallons of water. This will give you a mixture between 1% and 2% which will kill most undesirables and anything else that picks up the spray.
Jan 21, 2010 | Roundup "" Weed & Grass Killer
How much roundup do I use in a gallon of water to get a good kill
This will be hard to answer because roundup is sold in different strengths. On a dry morning mix a few ounces of round up to a gallon of water and test it by spaying it on some blades of grass. Results should be noticed after a few days.If you spent allot of money for just a little roundup then you probably have a strong solution. Some roundup is already mixed with water (diluted) and can be applied as is. I hope this helps
May 20, 2009 | Roundup "" Weed & Grass Killer
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
