Question about Samsung LN46A540 46 in. LCD TV
I have a samsung LN46A550 that has a clicking noise and the tv will not come on.
Dont know if you fixed it yet but one common defect is the power supply capacitors being faulty. 1 hour solution would be to change out the capacitors. or call samsung they from what i heard they can fix it for free quick it takes about 2 or 3 days.
Posted on Mar 25, 2011
Factory reset samsung
TV OFF _MUTE+182+POWER on remote control. or
Aug 18, 2014 | Samsung LN46A550 LCD TV
Samsung LCD TV 46 inch LN46A550 colors are all messed up.
My solution to that pixelation color problem was replacement of the flat wire connected to the Tuner board and video data board,must be new and original replacement part. I clean the terminals(don't brush just spray on)with electronic contact cleaner,let it dry or blow dry with hair dryer to vaporize left over liquid on both boards.Reason these flat wire problem is due to environmental(moisture)corrosion and breakage of the folded parts of the wire. I tested the replaced part and found breaks or cut ,we call it in electronic term"open connection".
Dec 18, 2012 | Samsung LN46A550 LCD TV
Samsung LCD TV 46 inch model LN46A550 has bright pink glow where it should be light (sky, lamp, etc)
My guess would be that you have a CCFL lamp that is failing. They will give off a pinkish tint when they are about to fail. But I would encourage you to get a professional diagnoses.
Oct 03, 2012 | Samsung LN46A550 LCD TV
Vertical lines left half of screen
You might be advised to look on EBAY for someone junking one for the parts----I do MFR. warranty work and from most makers it is nearly impossible to get replacement ribbon cables for sets....you sound smart so are aware issue could be inside the display panel as well....
Jun 09, 2012 | Samsung LN46A550 LCD TV
Samsung 46
Yes. There will be standby light ON, when you plug in the set to AC mains, if the front panel Power Switch is ON. There will ba a clik sound too. When you switch ON the set by its remote control, an other click also will be there.
Jun 07, 2012 | Samsung LN46A550 LCD TV
Samsung LN46A550 LCD power on/off problem again. Red light blinks 11 times, then clicks and then repeats the cycle. Only way to turn off is to unplud the set. Have checked capacitors and they are fine - no...
Apparently this is a known problem with flat panel TVs made a few years ago due to bad capacitors in the power supply. This same problem appeared in computer mother boards at about the same time so that the capacitors went open or shorted causing problems.There is videos on You Tube that addresses this problem see: http://www.youtube.com/watch?v=ZccykxrtX9g as a starting point and look around for other repairs
Jan 25, 2011 | Samsung LN46A550 LCD TV
I have a LN46A550 flatscreen...the picture is now only in the upper left hand part of the screen. It's basically 1/6 of the screen. I have tried to pull up the PIP function on the remote and it will not...
there should be a ratio button on the remote if not its deffinitly in the main menu click on 16/9 wide screen you seem to have the veiw secound channel working on you set but were is the big picture of the current show? anyhow try that and let me know how you went
merry christmas
Dec 22, 2010 | Samsung LN46A550 LCD TV
Samsung 650 LCD picture is cut off top and bottom
select the correct tv format, check your manual
Jan 01, 2010 | Samsung LN46A550 LCD TV
When i go to turn my tv on it makes a clicking sound and i get no picture. how do i fix this?
the power supply board has died and must be replaced. call 1-800-samsung or go to samsung.com to find nearest service center.
Dec 02, 2009 | Samsung LN46A550 LCD TV
My tv is not showing the color red
Hi my name is Roety,
I can help you with your issue ,
Please push in the component cables, usually the red one pulls out.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 02, 2009 | Samsung LN46A550 LCD TV
Samsung LN46A540 46 in. LCD TV Logo
396 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
