Installed 19 new Carrier CU's at 30 tons each. All sorts of alarm problems - reverse rotation, etc. Have you heard of any problems with digital scrolls by Carrier. MZ AHU application with split DX.
  • 455 Answers
Hello I hav'ent but they would be tight lipped if there was.Call CARRIER TECH SERVICE to send out a field rep to reslove your issues at once.
Posted on Sep 14, 2010
What is the width od a whirlpool fridge model number ET20DK
Hi Dennis:
Looks like the hermit answered this a while back.
hermit58
  • 33 Answers
SOURCE: can you give me the measurements height width
Depth Cab. Width Door Width Cab. Height Overall Height
Model size "A" "B" "C" "D" "E"
STANDARD MODELS
19 cu.ft. 30 3/4" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
21 cu.ft. 29 3/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
22 cu.ft. 30 3/4" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
INTEGRATED MODELS
19 cu.ft. 31 1/2" 29 1/2" 30 1/8" 65 1/2" 66 1/2"
22 cu.ft. 31 1/2" 32 1/2" 33 1/8" 65 1/2" 66 1/2"
ARCHITECT® SERIES MODELS
19 cu.ft. 32 7/8" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
22 cu.ft. 32 7/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
Jul 08, 2015 | Whirlpool Refrigerators
Temp alarm chimes can't find control pad to turn it off
look on the internet they might help you , type in the info you have about it.
Nov 10, 2012 | Maytag MBF1958XES - 30% E-Star, 19 Cu....
My 06e run high amprage anf trips my breaker
Hi jc escamilla
Check and repair your compressor unloader valves...
If they are stuck,broken,etc...then they will cause the problem you are experiancing.
Also check you oil level, low oil could be the cause also.
Please rate me
Bud
Oct 19, 2012 | Carrier 30 Ton Hvac Air Compressor (brand...
How many tons is this Carrier unit? Model #38AH-034---610AA Serial #OBO1F65263
This is a 30 Ton Hi Efficiency Gemini series unit from carrier you can matched to either of these air handlers.
40RM028 40RM034
Model is broken down in sections
38AH = carrier Gemini series units from 20 to 120 tons the numbers following the dash represent the size 024 = 20 028 = 25 034 =30 044 = 40 054 =50 the list goes on in increments of 10 untill it reaches 130 tons 134=130
Hope this helps
Best of Luck
Jun 01, 2011 | Carrier Heating & Cooling
Can you give me the measurements height width depth of the KTRC19KK?
STANDARD MODELS
INTEGRATED MODELS
Jul 07, 2009 | Refrigerators
Compressor and outdoor fan runs indoor fan does not. Has 230vac can't find capasitor has GE ECM motor carrier package unit 2 ton
cap usually mounted to blower housing with power off turn blower wheel if rough bad brown wires from motor should lead to cap if replacing motor get new mount belly band also and make sure rotation is correct reversable motor hope this helps
Jul 06, 2009 | Heating & Cooling
I am getting Circuit A and B suction transducer failure alarms I've replaced both transducers. Ive got 5vdc from red to blk and from green to red at the senser.The pressure reads 0psig on the marquee and...
Hey there, let's see if I can shed some light on your situation for ya. First of all, those noisy compressors are from the refrigerant feeding back through at shut off. Chances are, these are the compressors with the built in check valves and if they were replaced and doing it again makes you wonder if something is breaking them down. Also, if the are running at a real high pressure, the compressors may have enough pressure in them in front of the check valve to make them spin bckwards at shutdown. If it is two tandem compressors, I would vote for the latter. As far as the pressure xducers, I have never heard of that issue before after turning off and back on. I do know that the way carrier looks at its sensors is one at time and if one sensor is shorted, it will pull the voltage down and whichever sensor carrier is looking at at that particular time will show as a failure even though that one may not be bad. The way to identify this is to clamp on the pressure xducer wires with your meter and set it to min/max. If there is a short, your meter should go to zero (set on min). This will ell you there is a short somewhere, just up to you to find it. Let me know if this doesn't help or you need anything else
Jun 17, 2009 | Carrier Heating & Cooling
EVOLT E-500 LCD Problem (Mirror Image)
This is new one one. It would seem to be an electronic failure of some sort Suggest you refer to Olympus Support on this one
Aug 20, 2007 | Olympus EVOLT E-500 Digital Camera
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
