Question about HP Pavilion dv9730us Notebook
Cannot maintain wireless connection
Laptop is 95 days old. Has worked fine on my Linksys WRT54GS which was 3 years old. Router died and I bought a Linksys WRT310N and have about 35 hours invested trying to get it to connect. We have 2 XP Pro laptops that connect fine. The newest laptop with Vista will not even see the wireless network most of the time. Everything is updated. Latest Bios & driver updates from HP and all Windows Vista updates & Service pack 1. Finally got it to connect last night and it worked for approx. 40 minutes and now won't see the network again.
    Problem Solver:
  • 14 Answers
I had a similar problem with WRT54GS last month. I use it for both desktops and laptops at home. It had worked for 3 years. All of a sudden one desktop and 2 laptops could no longer connect. None of the machines had been updated. The mystery deepened because the other desktop an laptops we have still got internet access.
I used the drastic approach. It worked.
1. Reset the router to factory settings
2. Remove the internet cable connecting Modem/Router from the modem and insert it into a laptop or desktop
3. Open an internet browser
4. In the address bar type in the IP address 192.168.1.1 - if that doesn't work use 192.168.0.1
5. Re-install the router, required security (WEP, WAP), your new SSID and password
6. Remove the internet cable from PC/laptop and put it back into the modem
7. You will have internet connection
If this doesn't work then you will require a new router.
Posted on Jan 02, 2012
    Champion:
  • 230 Answers
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
Posted on May 15, 2008
The password comes back as invalid when I just used the same password to connect my Windows based laptop and my iphone to the Wifi......
Report Trouble with Linksys router WRT54GS [Solved/Closed] johnkwit 2Posts June 16, 2008Registration date - Jun 17, 2008 11:17pm BST - Last answer on Jul 27, 2010 5:27am BST hello Hello,
I have a new Linksys router WRT54gs and a new Dell laptop.
The router works well with the cable attached but when I go to wireless
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help.
Any help would be apreciated
Jan 05, 2011 | Computers & Internet
RESETTING WIRELESS ROUTER
You don't have to reset the router to use it for a wired connection. You will need an Ethernet cord connected directly to the device that you want internet connectivity for. Such as a Desktop or Laptop
I hope this helps. Have good day!
Jun 29, 2010 | Linksys Wireless-G WRT54GS Router...
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router (192.168.0.1) user name "admin
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
The wireless suddently dont work and cant be dectected for no reasons. and hours or days later it is back to normal without changing anything. weird... it started to do that couples of month ago. can you...
Take your wireless laptop or device, and do a wireless scan in your yardk or in your car. If there is more than one, check the wireless channel number that your router is broadcasting on. If your router is on the same number, it will cut out. Once you find out what free channel number is, then you need to change that router to that number and that should take care of it.
Oct 20, 2009 | Linksys Wireless-G WRT54GS Router...
I have an Linksys Wireless G WRT54GS router. I
This is strange... Never heard of it in all my years. Call Linksys www.linksys.com and then ask them becuase this is rare. If they can't find a solution just steal the internet :)
Oct 13, 2009 | Linksys Wireless-G WRT54GS Router...
I have a linksys WRT54g router set up to a desktop. I have 3 laptops on wireless - 2 laptops connect to the network just fine - but the 3rd laptop connects with limited connectivity. What can I do to get...
double check that your router is not broadcasting in only G, make it reverse compatible. There is a chance that the other laptop may not be G compatible. Also check the security key and make sure it is correct. If your blocking connections by MAC address make sure the MAC of the non functioning computer is added. You may want to delete the current connection settings from the laptop and restart with a fresh wireless connection. I hope this helps. Good luck
Sep 25, 2009 | Linksys Wireless-G WRT54GS Router...
New WRT54GS Router, Wired Desktop not working
To do this you would restor it back to factory which means old you programs and documents that have been added will be permatly lost inless you put these files on a usb flash brive or burn them to a cd.
Jan 04, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS router needs to be rebooted frequently
Try to leave of air for an hour, untill its cold, then reconect it, if the time untill it quit conecting is consitrly longer, your Linksys is dying.
/Teis
Dec 07, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect anymore
Does the router work with the wired port connection? It's entirely possible that the router just went belly-up on you ...Linksys is an awesome brand, but sometimes it happens.
If the wired part works, the wireless transmitter inside may have gone bad. Best to just get a new one for about $50 ...but keep the old one in case you need a wired connection somewhere else around the house :)
Sep 28, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
HP Pavilion dv9730us Notebook Logo
191 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
