Question about Miele W864 Front Load Washer
Describe your miele w863 problem locked door Problem and I can't open it
I have a miele novotronic washing machine w930 door wont open?
after leavening the machine off for at least 1/2 an hour and try again if not there is a problem with the door lock it may be faulty, unplug the machine take the top off and push the drum to the rear and using a small screwdriver remove the door lock and replace from the manufactures website eric
Jan 16, 2018 | Miele Washing Machines
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
My miele front loader beeping and display saying activated close stopcock.
Defective door lock switch Manual release in side back of door lock
may have pull wire near drain clean out.
Jul 05, 2016 | Miele Washing Machines
W863
dose it spin verry slow while it heats up , can u put it on just a spin if that dont work it could be motor
Apr 15, 2014 | Washing Machines
Miele w865 - door won't open after completed wash cycle
the solenoid sounds like it is defective on the door lock or the plug has fallen out of the door lock. if you remove the sealing ring clip which holds the door seal in place and pull back the seal you can reach inside the unit and make sure the plug is in place. check also there is power to the plug
hope this helps. if all else fails call the Miele service centre in your area and they will be able to help
May 08, 2010 | Miele W865 Front Load Washer
'Close the Door' on Miele WT 2670
Door lock faulty or wires to lock adrift.
Mar 06, 2010 | Miele WT945 Front Load Washer / Dryer
Miele W864 Front Load Washer Logo
64 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
