Question about Philips Audio Players & Recorders
I want to replace the darlington pair BDV64C/65C with 2SC500/A1943.
Looking for a basket for a fellows 65c
You can only buy new one or block a microswitch inside. Basket from Fellowes PS-67Cs can be used too. If you use this shredder privately just block the microswitch.
Nov 10, 2014 | Fellowes Powershred PS-65C Medium-Duty...
Missing Instructions
(516) 699-1000 Directions Map Website Add To Mybook
Apr 17, 2014 | Linon Home Decor Products Darlington...
Missing instructions
(516) 699-1000 linon home number they will email u
Mar 14, 2014 | Linon Home Decor Products Darlington...
AMD temp
AMD Athlon 90C - 95C AMD Athlon64 65C - 70C AMD Athlon64 Mobile 95C - 100C AMD Athlon MP 90C - 95C AMD Athlon XP 85C - 90C AMD Duron 85C - 95C AMD Opteron 65C - 71C AMD Sempron 90C - 95C AMD K5 60C - 70C AMD K6 65C - 70C AMD K6 Mobile 80C - 85C AMD K7 Thunderbird 70C - 95C
Apr 21, 2009 | Computers & Internet
Do you need a remote to fully power it on?
The problem was caused by a blown fuse. The secondary power supply was still functioning which powered the small LEDs and some of the switches on the front. The fuse went because a pair of the darlington driver transistors went (center channel I think) and some components on the rear speaker driver board.
Feb 16, 2008 | Sony STR-DE615 Receiver
Power cuts off Pioneer SD-P50A5-K about 9 years old
Probably started as a bad solder connection but if it's blowing fuse FU106 now, you're probably in for a new set as that usually means your convergence IC's are bad along with a pair of darlington transistors that's mounted to the heatsink nearby. With the age of the set it may not be worth the trouble. If no fuses are blowing, you could still have a bad solder connection near the Switched Mode Power supply transformer. If that isn't it, you could have a bad High Voltage Block and you may end up having to replace the deflection board as well thank you Pioneer.
Feb 02, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
225 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
