Question about Whirlpool Dryers
Elec dryer LFE6900W1 doesnot turn on Breaker is ok on/off switch was removed and tested ok dryer switch was remooved and tested ok
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
Where would I find the fuse(s)? , on a M460-G Elec Kenmore dryer?
Check the circuit in your main breaker box that feeds the dryer, I had this happen to me, and that was my problem, reset it, and the problem was solved for me. Good luck
Nov 04, 2014 | Kenmore Dryers
Dryer does not heat
Check the breaker first, then the wiring at the receptacle, then at the back of dryer. If that is ok , then remove top to see if any wiring is loose or burned. Since it spins, you will want to check the heating element for continuity. This could be the problem if all else is ok.on your breaker, it will be a double pole breaker. Though it may not be tripped, one leg could be, so then just turn it off then reset. I have found this to be helpful in most cases. Try all this, if it doesn't get, let me know back, I will be checking this often. One other thing to look at is the relay switch. It is located near the top under the cover it is about the shape of 8-10 quarters stacked up . To test it, just bypass the relay and if the heat comes on, you will know that it is the relay . It costs about 12dollars. Good luck, Bill
Jan 29, 2013 | Dryers
Dryer won't start turned off by itself, tested on/on switch is ok and turned circuit breaker off and on
hi they have a safety thermostat near the element that may have gone bad or the door switch is bad if its the safety tstat make sure your vent is clean jim
Oct 12, 2010 | Whirlpool LER4634J Electric Dryer
LG elec dryer will not turn on...
Check your breaker. When you swapped one of the hot legs (red and black) with the neutral (white) the breaker should have tripped as soon as you plugged it in. If the breaker isn't tripped, check the wiring diagram to see if there are any internal fuses in the control panel that might have fried.
Aug 29, 2009 | LG DLE2532W Electric Dryer
Dryer will not operate
This sounds like your motor is out. Also check out your start switch. Hope this helps.
Aug 14, 2009 | Dryers
Dryer elec. works great no heat
You either have a breaker tripped, a wire has burned off in the back, hi limit switch is bad(located under the hood) or last the element has burned in two.
Dec 02, 2008 | Kenmore 63942 Dryer
Dryer won't start
hi ..thanks for the question you can remove the front panel by removing 2 screws on the front, at the bottom of front panel. disconnect power . remove front the door switch can now be tested .
Sep 21, 2008 | Maytag PYE2300AY Electric Dryer
Amana dryer
Check your fuses or breaker. An electric dryer requires 240 volts to operate. In a fuse box system, 2-30 amp fuses are required for an electric dryer to operate. If 1 fuse is blown it will not start or heat depending on which fuse is blown.
In a breaker system the breaker can trip and sometimes look ok. Find your 30 amp dryer breaker and reset it by flipping the lever to off, then back on.
If this doesn't help, you may have a faulty door switch or maybe your door has loosened from the hinges and has sagged a bit, breaking contact with the door switch plunger.
If you can locate the door switch, push on the plunger... you should hear an audible click...if you do then the door switch is normally ok, but not always, it is just a simple test to rule a bad switch which is normally silent if it is faulty.
You may want to inspect for a burned wire or wire termination.
Make sure dryer is unplugged from the power source before inspecting!!!
Other than the previous instructions, it is difficult for a novice to diagnose the problem...call a technician in to fix your dryer.
1 more thing, Just because a breaker appears to be on, and/or you flipped it off then on, doesn't mean the breaker is ok. Fuses also can look good and be bad. A small volt-ohm meter($10.00) is a good investment for testing voltage, and to save time and money.
Hope this gets you up and running.
May 26, 2008 | Amana ALE643RB Electric Dryer
Dryer will not start, timer sounds like it is running
Possibly a door switch, or starting switch near timer assembly. it could also be a bad breaker, dryers have a double breaker, even if you are getting electricity to part of your dryer 1 bad breaker might not let the rest of the dryer work. With electrical experiance,and elect. tools, have some one test breakers and plug voltage.
Apr 08, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
19 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
