Paper jam in top section of printer and can not get at it to remove it how do I reove the top of the printer to get at it the printer is a HP 2600n
    Guru:
  • 317 Answers
If ur not able to open from front you can try from back side of the printer
Posted on Sep 13, 2010
PAPER JAM - HOW DO I REMOVE SHEET OF JAMMED PAPER
The 2600s have a door in the back that can be removed to gain access to any sheets that may have become jammed. The front panel opens in two stages, the second requiring a button press on the side to gain access. Using gentle pressure and left-to-right motions you can slowly pry the trapped page from the rollers (make sure the printer is off before you begin) Some amount of disassembly may be required if the page becomes torn, but refrain from using sharp objects to pry the paper free. If you are unable to find the jammed sheet, remove the paper drawer and check the feed rollers.
Nov 25, 2010 | HP Color LaserJet 2600n Printer
We have a HP Laserjet 2600N. There is a jam in the fuser delivery section. Someone tried to clear the jam but left torn paper inside. How can I remove the jammed/torn paper? Is there a lever that will...
I'm sorry to inform you I referenced the removal of the fuser as it's simple for most machines. However on the 2600 it's buried inside. If you can pull it out the machine will have to opened up to remove the paper. The process includes 18 steps to get it out.
If you want the instuctions on how to remove I can upload them to scribd and provide you with a link. Other than that it would require a service call to a technician or your IT department.
Oct 20, 2010 | HP Color LaserJet 2600n Printer
How to I open the top section of my HP Laser Printer 2600, it is jammed and I can't get to the paper.
Open front door and remove the cartridges. Remove the back and side covers.
Use a flat screw driver (or just your fingers) and lift the grey part of the top cover. Bend it left-right to unlatch the latches. There are 4 screws below it. Unscrew them and lift the top cover.
Aug 21, 2010 | HP Color LaserJet 2600n Printer
Jam in output tray --hp 2600n
Yes... Its been a while since I had to do the same thing. I believe you have to pull both sides and the back before you can get at it.
Aug 05, 2009 | HP Color LaserJet 2600n Printer
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
PAPER JAM AT TOP OF COPIER
top of the printer do not come off. it is clipped to the sides.
to access the output paper path, you need to remove all of the ink cartridges.
Jan 05, 2009 | HP Color LaserJet 2600n Printer
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Jul 27, 2008 | HP Color LaserJet 2600n Printer
Paper jam
The paper jams are in the fuser area. Which is very hot. The following is a link to change the fuser. It may be that you can get to the jam by removing the top cover.
Jul 01, 2008 | HP Color LaserJet 2600n Printer
HP 2600n printer
1-st of all remove the dark blue/gray top cover - from the back/top of the printer there are in L and R side 2 holes. Stick a slim screwdriver to release boath locks and lift it up. Under this cover U'll find 4 scrwes. Before lifting the white cover remove the R printer cover for removing the control panel cable. Once U remove the white top cover U can access the fusssing assambley.
Good luck.
Mar 11, 2008 | HP Color LaserJet 2600n Printer
Paper is jammed
Remove fuser unit. see operator book. (available www.hp.com)
Nov 06, 2007 | HP Color LaserJet 2600n Printer
26 people viewed this question
jasbo
jasbo
