Question about Panasonic KX-TG4500 Phone
Line 1 stopped ringing. The light lights up but does not make a sound. This is the 2nd unit we have had to do this
    President:
  • Panasonic Master
  • 860 Answers
To program the ringing on the cordless handsets:
Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press .
3 Scroll to “Ringer volume” by pressing
L The current volume is displayed.
4 Press {V} or {^} to set the volume.
L Each time you press {V} or {^}, the
volume will alter and the chosen volume
will sound.
L To turn the ringer off, press {V}
repeatedly until “Ringer off?” is
displayed.
5 Press .
L Confirmation tone is heard.
Posted on Sep 13, 2010
  • CreativeGift Packaging
    CreativeGift Packaging Sep 13, 2010
    NO it is not the ringer volume all other lines ring it is just line 1.
  • george  peters
    george peters Sep 13, 2010
    sorry about that.
    On the base unit.
    1 Press {MENU}.
    pressing {<} or {>}, then press
    {ENTER}.
    3 Scroll to “Ring group” by pressing
    {<} or {>}, then press {ENTER}.
    4 Press {<} or {>} to select the line
    (LINE 1 to 4).
    * The current settings are displayed.
    5 Press {<} to move to “Ext.#”.
    6 Key-in the desired extension
    number(s), using the keypad keys ({1}
    to {8}), or {INTERCOM} {1} to {8}.
    Enter {0} for the base unit.
    * Press {INTERCOM ALL} to select all
    extensions, press it again to de-select
    all extension numbers.
    * Press {CLEAR} to de-select all
    displayed extension numbers.
    7 Press {ENTER}.
    * Confirmation tone is heard.
    * To program another line, continue from
    step 3.
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
My phone stop the ring
This phone unit it is a cordless phone hand set unit phone,it is a home land line base phone wright?Yes? Did u tries ring high ring low on the phone hand set functions up and down of the phone itself have a ring functions so u make sure is it not the phone unit functions itself.Did u try other phone unit on that phone land line to make sure it is not the land line phone line problems.U can tries take the corless hand set nocking it on a hard surface lightly a couples times.This could clean some dust and dirt loosen or stuck function buttons.The cordless phone hand set battery it is charging?Yes? Phone might have a weak or dying or a dead litium battery.Tries the phone unit itself unplug/replug it back like about and hour later for phone unit to reboot itself.
Oct 04, 2011 | Lands Phones
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
I can't get the light or the bell to stop flashig or ringing on the berkley pole tap.what do i do?
You MUST have the LED light facing down towards the reel when it is attached to the rod. If it is attached upside down with the LED facing up it will continue to flash or beep nonstop. The simple instructions for the Berkley poletap is -
1.Turn the unit to light or sound.
2.Cast your line,( it will blink or beep as you cast).
3. Set unit in rodholder or against chair,(Poletap will blink or beep about 12 seconds and then stop when still).
4. When a fish nibbles or strikes the poletap will alert with your setting of light or sound.
You may want to check out the new Berkley Poletap Pro, It has complete sensitivity settings for windy days and Tilt - angle for slow pull fish, high current and trolling mode.Awsome product!
Check it out at this Berkley site.
http://www.berkley-fishing.com/prod.php?k=299309&sk=299309&p=PURBAPPBA%20(11187809)
Oct 04, 2009 | Berkley Twist Lock Rod Rack
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
Lucent Partner 18D - stop ringing of line 2 at phone
From extension 10 or 11
Press feature 00
Left intercom
Left intercom
right intercom
all lines that are programmed on your phone will light up.
Solid means immediate ring. Slow flash means delayed ring. Really fast flash means no ring.
Press the line you wish to not ring, 2 times.
Feature 00 when you are done.
Oct 14, 2008 | Lucent PARTNER18 Corded Phone
RCA executive series
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Mar 30, 2008 | RCA 25202RE3 Corded Phone
Panasonic KX-TG4500 Phone Logo
559 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
