Question about HP LaserJet 2605dn Printer
We have an HP 2605 color printer. It began squeaking a few weeks ago when printing. Do I need to see about cleaning the rollers?
JackHeath
  • 1049 Answers
SOURCE: Roller
Try changing completely or at least first cleaning the glassy surface of the toner cartridge first. You can do it with a cotton swab by sweeping the black toner from the surface while manually turning the gear on the side of the cartridge.
Posted on Jul 23, 2008
  • 10 Answers
SOURCE: Hp Color Laserjet 2605 dtn
Should be under warranty, call hp and get them to replace it
Posted on Oct 16, 2008
  • 66 Answers
SOURCE: HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Posted on Jan 02, 2009
  • 81 Answers
SOURCE: HP color laser 2550l prints only yellow
Are you sure that none of the other colours are empty? If they are then this could be the problem
Posted on Jan 03, 2009
leroyal
  • 2120 Answers
SOURCE: Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
Posted on Feb 07, 2009
I have owned numerous black & white HP laser printers and numerous Konica color laser printers. I purchased 2 HP Color Laserjet CP3525N printers new from HP 1.5 years ago. Now they both squeak loadly...
The squeaky wheel gets the grease! Yes it's a mechanical problem. The paper feed rollers and gears are loaded with paper dust and need to be cleaned or replaced.
Jul 26, 2011 | Dell Studio Xps 9100 Desktop Computer
Squeaking sound in area of roller bar when printed copy is delivered into tray. printer purchased new 3 weeks ago
Return under warranty is the best thing to do. Trying to repair it yourself will void the warranty.
Jan 19, 2011 | HP Officejet 6500 AllInOne InkJet Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
Color LaserJet 2600n Some of the colors are not printing.
replace color cartriges restart and let computer clean the heads
Jul 29, 2009 | HP Color LaserJet 2600n Printer
Jan 01, 2009 | HP Color LaserJet 2600n Printer
Oct 16, 2008 | HP LaserJet 2605DTN Color Printer
163 people viewed this question
Seeker5211
Seeker5211
